My design was almost the same. I used two MOSFETs (common drain / common source) though. Reason:
- Better Current Handling
- Quicker Turn-OFFs -- Because when you use diode OR-ing you loose the low going edge that turns off the MOSFETs fast
Also I used an active Op-Amp amplifier for the current signal.
The link you posted should work absolutely fine.
