bit, byte or word?
Results 1 to 6 of 6
    Default bit, byte or word?
    Hello Everyone. I thought I had this figured out but someone's post has confused me. At the top of my program I put:
    x var byte
    now, any reference to the adcin command reads back to me a number from 0 to 255 when I put it into x. It works perfectly. Now, if I put:
    x var word
    what number will it read to? I thought is was 0 - 1023 but someone's post refers to the number being 65535.
    One more - what will x var bit read to? - Thank you.
    A word is 16 bits...
    16 bits gives you a range from 0-65535
    The internal ADC in most PIC's is 10 bits...
    10 bits gives you a range from 0-1023
    You need a WORD variable if in PBP you want to play with numbers bigger than 255 (a BYTE). When reading from your ADC, your WORD variable will acquire a value in the range 0-1023... the upper bits will be zero.
    Thank you Melanie. And how about a bit variable? What does that count up to? Thank you.
    I never thought I'd find myself answering this one but...
    A bit is the smallest variable you can have... represented by one wire, one pin, one-eighth (1/8) of a byte... in the Digital world, this can only be Zero (0) or One (1)... there is no other state.
    So the variable range for a BIT is 0-1. It's either a Zero or a One, that's it...
    Like I always say to everyone... if you can count to ONE, you're a computer expert, because that's all ANY Digital computer does... it just might happen to do it damn quick, but basically if you can understand that concept, then that's all there is to computers... micro, mini or mainframe... if you can count to one (or have an IQ equal to or greater than a BIT), you too can earn big bucks...
    Thank you Melanie. My IQ = a bit but I don't make big bucks.
    Life isn't so bad... it still rates you over the average Politician, Lawyer, Real-Estate Agent...
    Last Post: - 14th June 2016, 07:55
  2. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
