Laptop Serial connection how to
Results 1 to 3 of 3
    Bombay, India
    Sumobob:
    Welcome to this forum. Hyperterminal would try to look for a configured modem to talk with. That is why it is asking for a number to dial etc. What you need to do is to find out via the SYSTEM PROPERTIES window as to which COM device your USB converter emulates.
    Now, open a new connection called "XXX" or whatever you want and configure it. Choose the option "CONNECT TO' using COMxx which is the COM device you found your USB-COM to be emulating. This option is found in the Connection Properties button on Hyperterm. Thats all there is to it. I hope I haven't forgotten anything here.
    Jerson
    Sep 2008
    Arizona
    Thank you very much!
    I can program the PICs that I use but never had to use a debug to figure out why my code was not functioning as expected.
    This will help me very much.
    Cheers,
    Bob.......................
  1. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  3. Failure Serial Connection with Hyperterminal
    By guanerrr in forum Serial
    Last Post: - 5th August 2007, 07:49
  4. serial connection n vb interface
    By gidah in forum Serial
    Last Post: - 18th September 2006, 13:54
  5. Sharing Serial connection
    By DynamoBen in forum Serial
    Last Post: - 9th March 2006, 18:07
