write big text to lcd
Results 1 to 4 of 4
    brighton
    Angry write big text to lcd
    Hi All
    Has anyone being able to write big text to an lcd like this ?
    http://www.siwawi.arubi.uni-kl.de/av...ock/index.html
    Isaac
    Here's a port of Scott Edwards' BigNums to PBP. Originally for the Basic Stamp.
    http://www.picbasic.co.uk/forum/showthread.php?p=26736
    Quote Originally Posted by isaac View Post
    That's just a standard 4x20 LCD, half a dozen 'special characters', angled block types, half filled block, filled block, etc..etc.. It's all in how you put it on the screen.
    If you forgo the 'special characters', you could do the same thing with an 'X' in each position to ultimately make a LARGE font... No special programming required, just a little bit of thought...
    May 2007
    Have you considered using a graphic LCD instead?
  1. Replies: 2
    Last Post: - 5th November 2009, 17:07
  2. Play with LCD on PICDEM
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
