How to know what pin triggered an interrupt?
Results 1 to 20 of 20
    I may be wrong, but I can not think of a PIC that has a porta interrupt.
    What PIC are you using?
    I would read the port as fast as possible (immediately on interrupt) by saving it in an 8-bit
    variable, and then testing for the port bit in question stored in my variable.
    MyPort VAR BYTE. MyPort=PORTA. Now test bits in MyPort for the change.
    Edit:
    The only interrupt flags available are those shown in the data sheet.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    xnihilo's Avatar
    xnihilo Guest
    Edit:
    That's exactly what I'm doing (see my code below) but I have the feeling it makes me waste some time doing all the stuff only to know which pin triggered the int
    DISABLE 				'disable individual interrupts while executing the interrupt routine (do not put check interrupts calls after each instruction)
    in_sig:
    'MEMO: first read the port THEN clear the flag otherwise mismatch still exists
    'Contribution from: Darrel Taylor (www.picbasic.co.uk/forum/)
    a = porta               'read port to clear mismatch
    'TEST block
    HIGH portc.2
    'check what pin triggered the int
    'we have the time of the header pulse to manage that work
    if (a.0(0) == 0) THEN
        pin = 0
        GOTO got_pin        'bypass
    if (a.0(1) == 0) THEN
        pin = 1
    if (a.0(2) == 0) THEN
        pin = 2
    if (a.0(3) == 0) THEN
        pin = 3
    if (a.0(4) == 0) THEN
        pin = 4
    got_pin:
    This works, then I have to use porta.0(pin).
    May 2007
    I may be wrong, but I can not think of a PIC that has a porta interrupt...
    Unless he is using a PIC24 - which can have interrupts on every port.
    If PBP supported the 24 series it would be nice..;o}
    -Bruce
    tech at rentron.com
    xnihilo's Avatar
    xnihilo Guest
    PORTA and PORTB have it. You can choose which pin change can trigger an int but then you only have an INT flag that tells you some port pin triggered an int, it's up to us to check which one did it.
    xnihilo's Avatar
    xnihilo Guest
    Yes, it is called portA on change interrupt, there are also portB on change interrupts.
    It exists on the models I'm using: 16F684, 16F690, 18F452. Very useful by the way.
  1. Can't ID interrupt source with this IntHandler??
  2. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
