Basic PIC circuit acting weird
Results 1 to 4 of 4
    Jun 2007
    Default Basic PIC circuit acting weird
    Hi
    I'm following a basic PIC tutorial. I've assembled a circuit on my bread board to flash an LED. I'm using the PIC 16F886 with a 5V AC to DC converter (500 mA max).
    The Setup:
    5V going to the Vdd
    5V to MCLR through 11.5 kOhm resistor
    Vss to ground
    5V to RC oscillator w/ a 11.5 kOhm resistor in series w/ a 27 pF capacitor to ground
    OSCin is connected to the RC oscillator between the resistor and capacitor
    220 Ohm resistor from port B to an LED to ground
    The problem:
    The circuit doesn't work unless i'm physically touching the LED wire or the resistor coming to it. I checked my connections with a multimeter but they seem ok. The port doens't seem to output voltage UNLESS i'm touching it.
    LOL this is driving me insane. Any ideas on what's happening.
    Post your code, PIC number. Do you have a regulator in your power supply? Capacitors ? Have you set the TRIS and PORT registers? Have you set the config fuses? Are you using Resistors to tie the unused ports to either ground or VCC ?
    May 2008
    Italy
    your oscillator does not work! It start oscillating when you introduce disturbances with your body antenna. Replace oscillator with something that surely oscillate as a ceramic resonator.
    Jun 2007
    you're right, i hadn't set the right oscillator setting on the pic.
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  2. Replies: 3
    Last Post: - 29th October 2006, 10:16
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 05:07
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 14:07
