Long config line
Results 1 to 6 of 6
    Default Long config line
    Well, it might sound stupid but, how can I break this long configuration line in two as it is too long to be printed or displayed on-screen? This line compiles OK:
    @ __CONFIG _CONFIG1, _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON & _CP_ON & _MCLRE_ON & _PWRTE_ON & _WDT_ON & _HS_OSC
    The idea of multiple @ __CONFIG lines won't work:
    @ __CONFIG _CONFIG1, _BOR_ON & _CP_ON & _MCLRE_ON & _PWRTE_ON & _WDT_ON & _HS_OSC
    It produces an Overwriting previous address contents (2007) error.
    Thanks for the care,
    It won't work the way you want it to work... Not all of those CONFIG options are location in CONFIG1, some are located CONFIG2L, CONFIG2H, and so on and so on...
    And since I'm not 100% sure which PIC you're using, I can't tell you which option goes where.
    This is one of my old config setups for a PIC18F4620.
    @ __CONFIG    _CONFIG1H, _OSC_HSPLL_1H & _FCMEN_ON_1H & _IESO_ON_1H
    	;_HSC_1H=HS, HSPLL_1H=PLL	'4xPLL on, failsafe/switch-over on
    @ __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L & _BORV_3_2L
    	;powerup timer on, brown out off
    @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_32768_2H
    	;'wdt off
    @ __CONFIG    _CONFIG3H, _MCLRE_OFF_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_PORTC_3H
    	;mclr is i/o, t1osc off, porta digital
    @ __CONFIG    _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    	;stack overflow , lvp off, xinst off, debug off
    @ __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    	;all code protection, eeprom write protection off
    @ __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __CONFIG    _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    EDIT: Just noticed the 'Overwriting.....(2007) error... So, yes, it is a 16F... Kinda hard to get that error with an 18F...
    I won't work the way you want it to work... Not all of those CONFIG options are location in CONFIG1, some are located CONFIG2L, CONFIG2H, and so on and so on...
    It will work the way he want's it.
    Almost all the options are in the CONFIG1 word.
    There are no CONFIG2L or H. Because even though I'm not 100% sure which PIC he's using.
    I'm 100% sure it's a 16F.
    @MyConfig = _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON
    @MyConfig = MyConfig  & _CP_ON & _MCLRE_ON & _PWRTE_ON & _WDT_ON & _HS_OSC
    @ __CONFIG _CONFIG1, MyConfig
    Thanks for the replies. Sorry I forgot to mention the MCU, that is 16F887... I did it like a newbie!
    Well, the solution of Darrels is clever. Where is this trick described? On MPASM manual maybe?
    Probably won't find it in a manual. It's just a single value.
    When you do something like ...
    You might as well put a couple parenthesis around everything ...
      __CONFIG _CONFIG1, (_DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON)
    Because you're really only giving it a single value.
    So you are free to figure out that value on your own, before supplying it to the __CONFIG statement.
    Binary Math, it's a wonderful diversion.
    Suddenly there was light!
    Yeah, that '&' is really a binary addition to the total value to be placed at 2007 address...
    All are simple and easy now!
  1. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  2. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  3. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  4. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
