Stupid question about LCDOUT
Results 1 to 22 of 22
    Sep 2008
    Stockholm
    Did you notice the reversed pinout numbering ??? ... from right to left.
    Yes, I have the datasheet for the displays since I used them in aother project (connetced to the parport of a computer)
    Quote Originally Posted by Glenn View Post
    Using one of those 'solderless breadboards' for the project?
    Double check those connections!!! They might be hooked up right, but are they making contact...
    Sep 2008
    Stockholm
    Yes I do, actually a new one I never used before since the other one is used for my servotests
    I measured the Vss and Vdd on the display to see that it get power, also that it get some power at Vo, but none of the other connections, but maybe I should..
    Right up there with the heartbeat LED, I usually put a 'blink all pins at x frequency' subroutine in there to do nothing but pulse all the pins at a known rate. Hit 'em with the logic probe or the 'scope and those questions go out the window...
    Solderless breadboards-These days, my older breadboards are usually the first suspect...
    Sep 2008
    Stockholm
    I guess I can try to move the whole project to another part of the breadboard or another breadboard to test.. or trying to find the probs for the scope
    Anyway, this is waht it looks like now.. yea, I know its not a school example of how it should be done but it should work.
    http://safir.amigaos.se/bildgalleri/...0-halfsize.jpg
    A few questions...
    Why the double-pullup resistor on RA4? Same on MCLR?
    Pin 9 on the PIC should go to pin 6 on the LCD...
    Almost looks like the LCD needs to be jammed in there a bit farther...
    Also, you really need more decoupling cap's... a couple across Vdd/Vss on both the PIC and the LCD (especially the LCD in this case) wouldn't hurt.
    Ok, I missed the part where you said you swapped over to an 'F84A.
    Those 1st 3 solder joints on the LCD don't look that good either, could be the lighting though...
    I may be full of you know what...
    But I think the LCD is wired backwards. I do not have the data sheet for that one, but isn't pin 14 over by the mounting hole?
    Sep 2008
    Stockholm
    A few questions...
    Since I have alot of 10K resistors handy and didnt want to search for 4K7 in my big pile of resistors I used two 10K in parallel to get 5K ..and since its only a pullup its not very critical anyway.
    The pinstrip I used have pretty long (and very thin) pins so its no problem.
    You mean closer ? Well, I guess I could do that just to get that possibility out of the way, but I dont think it should be any problem, I use a very clean powersource and have one cap on the breadboard over Vss and Vdd.
    The leftmost ones ? its actually flux that went white when I pressed the testpins from my multimeter to see if I really got some power to the LCD ..So no problem there, but I admit that the solderings on the ICSP-connector looks like crap ..I just made a cable between the Pickit2 and a pinstrip very quickly since I was tired of connecting and disconnecting the pickit2 all the time.
    Sep 2008
    Stockholm
    Ok, no I changed the pic to a 16F84A, and connetced a Xtal and two caps, still doesnt work
    Very strange.
    Now I test with:
    @ device HS_OSC,WDT_OFF,PROTECT_OFF
    DEFINE OSC 4	' Lets work at 4MHz
    DEFINE LCD_DREG	PORTB
    DEFINE LCD_DBIT	4
    DEFINE LCD_RSREG	PORTB
    DEFINE LCD_RSBIT	1
    DEFINE LCD_EREG	PORTB
    DEFINE LCD_EBIT	0
    DEFINE LCD_BITS	4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS	2000
    DEFINE LCD_DATAUS	50
    pause 500 ' grace time for the LCD to initialize.
    	LCDOUT $FE, 1, "Hello world" ' Clear display and show text
    	high portb.0	' Turn the LED on.
    	pause 1000	' Wait 1s
    	low portb.0	' Turn the LED off.
    	goto main	' Go back
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
