Well, since I got some help from you guys with my servoproblems I now have a more or less working routine for that, well, now I wanted to have a LCD to put some debug data to, reading the PBP manual it looks so easy, so I started with building the example in PBP manual:
http://www.melabs.com/resources/pbpm...2-5_35.htm#535
The only change I did was using a 16F628A instead of the 16F84A, therefore I removed the xtal and the two caps.
Then I wrote a very small program like this:
Well, nothing happens.. no sign of text on the LCD, no matter how I adjust the pot.. and I cant see why ?Code:@ device INTRC_OSC_NOCLKOUT,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF DEFINE OSC 4 ' Lets work at 4MHz CMCON = 7 ' Disable comparators pause 500 ' grace time for the LCD to initialize. main: LCDOUT $FE, 1, "Hello world" ' Clear display and show text pause 1000 ' Wait 1s goto main ' Go back
The LCD is a Sharp LM16A211, which is Hitachi 44780 compatible, and I also have used several of these for other applications so they are ok.
..I also like the idea with a heartbeat (Even if it doesnt look as nice at it does on my old HP PA-RISC machine
