Ive managed to sort it out. I almost came back with the info but i wanted to try and fix it myself. Ok, it took about 3 hours but i got there in the end.
Ive tried changing the pre-scaler too. i thought maybe a 2:1 ratio would free up a little extra processing time. Well, in theory it should because the PWM side of things is only using half the processing power. Unfortunately it didnt affect it in the way i wanted at all. All it did was make the lights flicker a bit because they were flashing too slow so i disabled the pre-scaler.
Now then, theres a sort of random problem. I currently have VB 6 in a loop sending 513 bytes of data. The PIC is processing the data and setting the PWM values. Well, its setting the same values over and over but its still processing and holding different colors in different PWM positions. Its actually working perfect
Now the random problem. If i have a scroll bar that sends the data in the onchange/onscroll then the LEDs flicker quite bad. I really dont understand how that could happen. The circuit is obv working and im sending 513 bytes of data so the baud rate isnt so high that its affecting it. The only thing i can think of is the gap between the last byte and the first byte of the next set of data is less than the gap between the bytes in 1 packet. That seems impossible though and if it did that then i wouldnt have thought you would notice.
Do you have any ideas? I just cant get my head around this one
Edit: Ive added some code to time the serial data going out of VB. Aparently it sends a full 513 bytes every 35-46 milliseconds and thats when it works fine
