PIC speed problems
Results 1 to 40 of 40
    Quote Originally Posted by The Master View Post
    So if i have a main loop that doesnt pause or anything then would it make sense to only have an interrupt for the PWM and repeatedly check PIR1.5 in the main loop?
    No...PIR1.5 (i.e. the serial port, either TX'ing a byte or RX'ing a byte) will trigger an interrupt if properly set up...that's the way interrupts work. If you can't get an interrupt to trigger, it might be because there's nothing there to trigger that interrupt and/or your serial port isn't working in the first place.
    Jun 2007
    Mansfield, UK
    What i meant is that the interrupt would copy the byte from RCREG into a temp variable. Then the code in the main loop would need a way of knowing when a byte has been received to process it (possibly a bit variable). What im saying is why not just check PIR1.5 instead of having another variable to say serial data has arrived and why not use RCREG directly in the main program loop instead of having another byte variable. It would mean the serial interrupt completes much quicker because it doesnt do anything.
    Should i be removing the byte from RCREG in the interrupt? If it doesnt matter as long as i do it before the next one arrives then doing it in the main program loop looks like a better way of doing it
    Well, if you're receiving serial data in packets, the main loop should know when a full 'packet' has been placed into the 'buffer' and the main loop can clear the 'buffer' once it's done with it so the interrupt can start loading it again.
    '4 byte buffer
    Int: buf[3] = buf[2] : buf[2]=buf[1] : buf[1] = buf[0] : buf[0] = RCREG
    RESUME
    Everything in the receive 'buffer' got shifted up one, and the newest byte is in the lowest buffer position...
    Now the main loop looks at all four bytes, decides it's a good packet, copies the packet and clears it so the interrupt can reload it.
    Problem with that is 'feature creep'... You never know what you're going to put into the main loop later on. You say you won't add that much...but who knows how many 'not that much's are going to creep in later on. If the interrupt handles it, it's handled, 'nuff said.
    Jun 2007
    Mansfield, UK
    I see your point. I will be adding some extra stuff to the main loop but the other stuff will only get executed if the current bit doesnt.
    It just seems like your way does a lot of unnecessary stuff. I can give it a go but it looks like a lot of processing that doesnt need to be done. Having said that, you know what your talking about and im new to this. Plus you say your code actually works and mine still doesnt
    It really doesn't do a lot of extra/unnecessary anything. All it does (or rather would do) is, the interrupt's would handle the PWM'ing on the LEDs for you (you update them in the main loop as required) and would handle putting any serial data received into a buffer (you pull the buffer in the main loop to update the LEDs brightness levels in the main loop as required).
    Really very simple...That file that I attached earlier has a whole LOAD of code in it for handling various modes for this, that and the other thing (sleep mode, flashing, fading, color 'phasing', etc.etc.)...a LOT of stuff you wouldn't even come close to needing for your setup.
    I modified that file I was talking about...4 channels (RGBW)...
    Change it up a bit to fit your PIC and hardware and try it out. No serial support, but it'll show you how the main loop can work PWM'ing with interrupts on the LEDs.
    The LEDs MUST be on portA for this exact code to work right. If you split up the LEDs between different ports, they may flash a bit funny...
    Jun 2007
    Mansfield, UK
    Ok, thanx. Im home now and im having a little trouble getting the timer interrupt working so ill read that file and see if i can get it working
    You're still using a 16F87 right?
    How about your hardware? How's that all hooked up? LEDs? Serial input? Anything else hooked up?
    Get me that info...lemme cook on it for a bit...
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. Pic Vrs Atmel speed
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 26th April 2008, 22:50
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. IC2 pic 18f452 program problems
    By MrSafe in forum mel PIC BASIC Pro
    Last Post: - 20th September 2007, 19:55
  5. Help, problems first time with 18F452 PIC
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 21:49
