Writing to 1-wire EEPROM
Results 1 to 11 of 11
    Apr 2007
    Santiago, Chile
    Unhappy Writing to 1-wire EEPROM
    I need to write to and then read back from a 1-wire EEPROM.
    I have an iButton DS1973 which has the same insides as a
    standard 1-wire DS2433 4Kb EEPROM.
    I have read the datasheet, tried without success, searched the PBP and other sites but no answer.
    I just need an example on how to write 1 byte to an address on the EEPROM and then read it back again. This code I tried but doesn't work:
    ADCON1=7 ' Set all Ports to Digital I/O
    OPTION_REG.7=0 ' Enable weak PullUps
    TRISB.0=0
    MEM VAR BYTE
    RESULT VAR BYTE[4]
    iButton var PortD.2
    START:
    SEROUT2 PORTB.0,16416,["START",10,13] 'just to test the comms
    'WRITE TO EEPROM
    OWOUT ibutton,1,[$CC,$0F,$00]
    OWOUT IBUTTON,1,[$54,$65,$73,$74] 'write characters "test"
    OWOUT IBUTTON,1,[$CC,$FF,$A5]
    PAUSE 25
    'READ FROM EEPROM
    OWOUT ibutton,0,[$CC,$F0,$00]
    FOR MEM=1 TO 32
    OWIN IBUTTON,0,[RESULT]
    SEROUT2 PORTB.0,16416,[RESULT]
    PAUSE 100
    NEXT MEM
    Can anyone tell me what I have done wrong?
    Chris
    Apr 2007
    Santiago, Chile
    Red face CRC for iButton EEPROM
    I am only going to load data on the iButton EEPROM once, is it nessesary to use the "Cyclic Redundancy Checks" to write to the device or is it just an option like parity is on other serial systems. Can I not just write directly to it without vast CRC calculations and then read it out to check? I only am going to need about 12 bytes to be written in total for button identification. (I am using the code on the button to change a pic's options, plug button 1 in it does one thing, plug button 2 in it does another)
    It must be simpler?
    Chris
    The Write Scratchpad command requires a 2-byte address. You're only giving it 1.
    OWOUT ibutton,1,[$CC,$0F,$00,$00]
    After that command, you can't "RESET" before the data
    OWOUT IBUTTON,0,[$54,$65,$73,$74] 'write characters "test"
    Not sure what this was supposed to be. There isn't a $FF command. Due to the delay afterwards, it looks like that was supposed to do the Write.
    PAUSE 25
    But instead, you need to READ the scratchpad memory to get the correct authorization code, so that you can do a "Copy Scratchpad" that actually writes it to EEPROM.
    After that, you can do the "Read Memory" command. (With 2-byte address again)
    Look at the COPY SCRATCHPAD [55h] section in the datasheet.
    hth,
    Apr 2007
    Santiago, Chile
    Talking iButton
    Thanks Darrel,
    Does this mean that I don't have to use the CRC calculation system?
    Chris
    Quote Originally Posted by crhomberg View Post
    Unless you want a program that's not susceptible to spurious noise Errors, NO, you don't have to use CRC's.
    Apr 2007
    Santiago, Chile
    Red face EEPROM still not working
    I modified my program using the authorisation code but I still seem not to get my data back.
    This is my latest version (for a 16F877A)
    '* Name : eeprom.BAS *
    @ device hs_OSC, wdt_on, pwrt_on, protect_off
    DEFINE OSC 20
    TRISC.0=1
    TRISC.1=1
    TRISC.2=1
    TRISB.0=0
    iButton var PortD.2
    MEM VAR BYTE
    RESULT VAR BYTE[4]
    Taddr var byte[2] 'target address 2 bytes
    ES var byte 'ending offset data status
    START:
    'WRITE TO EEPROM
    OWOUT ibutton,1,[$CC,$0F,$00,$00] 'Write to scratchpad
    OWOUT IBUTTON,0,[$54,$65,$73,$74] 'Write characters "test"
    OWout IBUTTON,0,[$CC,$AA]
    owin ibutton,0,[Taddr[0],Taddr[1],ES] 'read back the scratchpad to get the Authorisation code
    owout ibutton,0,[$CC,$55] 'Write back the contents of the target address & E/S register
    owin ibutton,0,[Taddr[0],Taddr[1],ES] 'to allow copy scratchpad to take place.
    PAUSE 25
    'READ FROM EEPROM
    OWOUT ibutton,0,[$CC,$F0,$00,$00]
    FOR MEM=1 TO 32
    PAUSE 100
    NEXT MEM
    Where have I gone wrong?
    Chris
    Apr 2007
    Santiago, Chile
    Talking At Last Working
    Thanks Darrel,
    I got it right, it is now send back the letters test with this code...
    'WRITE TO EEPROM
    OWout IBUTTON,1,[$CC,$AA] 'get ready to read scratchpad
    owout ibutton,1,[$CC,$55] 'Write back the contents of the target address & E/S register
    owout ibutton,0,[Taddr[0],Taddr[1],ES] 'to allow copy scratchpad to take place.
    PAUSE 25
    'READ FROM EEPROM
    OWOUT ibutton,1,[$CC,$F0,$00,$00]
    FOR MEM=1 TO 4
    PAUSE 100
    NEXT MEM
    Thanks Chris
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
