pulsin: how is it used
Results 1 to 15 of 15
Threaded View
    xnihilo's Avatar
    xnihilo Guest
    Default pulsin: how is it used
    Hello,
    I would like to use pulsin to record the length of a positive pulse, thus I would use
    pulsin trigger,1,pulse_length
    if trigger is a pin name and pulse_length is a word variable
    As I don't know when the trigger will happen, can I jump to the pulsin when I detect a low to high change on a pin (using a polling loop or an interrupt) or is PULSIN expecting to see the rising edge.
    As I understand it from the manual, it will record the pulse even if already on and will stop recording once the pin goes low, it it right?
    I don't know if my question is clear enough?
    'preset the pic specs and config words at chip programming time
    @        device  pic16F684, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off, mclr_off, protect_off
    DEFINE OSC 8			'set OSC value to 8MHz for instructions PAUSE, PAUSEus and SOUND
    'VARIABLES declaration
    'IF VARIABLES USED FOUR COUNTER GO OVER 256, USE WORD INSTEAD
    pulse_length var word
    CLEAR                     'clears all data ram (128 bytes) and initialize variables (this should however be done in software)
    INTCON = 0              'disable interrupts and reset int flags
    IOCA = %000000
    'PWM (single output mode) related registers for porta.5.
    'PWM is not used. We use normal output on C5.
    T2CON = %00000000			'value:4, 1:1 postscale (unused), Timer2 is OFF, Timer 2 Clock prescaler = 1
    PR2 = %00110001			'value: 49, PWM Period: 40.0KHz
    CCP1CON = %00000000		'capture/compare/PWM module OFF, no pwm signal on portc.5 at this time
    CCPR1L = %00001111		'value: 15, PWM Duty Cycle 8 MSB of 10 bits (2 LSB in bits 5 and 4 of CCP1CON), total: 60d
    'Setting registers
    OSCCON = %01110001
    CMCON0 =  %00000111			'comparators OFF, val = 7
    ANSEL = %00000000			'choose digital i/o, val = 0
    OPTION_REG = %01111111 			'enable porta weak pullups (no weak pull-up available for porta.3), p12
    'Setting ports states, direction and internal weak pull-ups
    'USE 10K WPU on RA3 if used as input !!!
    TRISA = %000001 				'set porta pins directions (1=input, high impedance),portA.3 is always input pin (datasheet p5)
    TRISC = %000000
    'use 10K WPU on A3
    WPUA =  %000000
    PORTA = %000000 			'set port pins logic, A0 will be a default LOW with 100K WPD
    PORTC = %000000 			'set port pins logic
    'aliasing pins
    Symbol trigger = PORTA.0
    SYMBOL led = PORTC.3
    PAUSE 3000             'let the power level stabilize if not already done
    'flashes at 5Hz
    for i = 0 to 4
        High led
        PAUSE 100
        LOW led
        PAUSE 100
    NEXT i
    PAUSE 2000
    start:
    While (trigger == 0) : WEND        'while pin is low (no pulse on pin)
    'a pulse has been detected (at this step the rising edge is over, the pin is high)
    PULSIN trigger,1,pulse_length   '16 bits
    WRITE 0,pulse_length.lowbyte
    WRITE 1,pulse_length.highbyte
    'flash when recording occured and finished (max 327ms with 8MHz 5 us resolution 65536 increments)
    HIGH led
    PAUSE 2000
    LOW led
    goto start
    END                     'end of program
  1. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
  2. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  3. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  4. Pulsin to pulsout with up than 4MHZ crystal ?
    By RCtech in forum mel PIC BASIC
    Last Post: - 18th May 2006, 20:23
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 15:45
