Bearing calculation out of 2 nmea strings
Results 1 to 10 of 10
    Aug 2003
    Default Re: Bearing calculation out of 2 nmea strings
    You should be able to cycle a list of waypoints,
    measure the distance to all of them,
    find the closest, calculate the bearing, and draw an arrow pointing to it.
    Was that the idea?
    I finally got PBP working with MPLab again today,
    The trig functions should be fine to rotate points around a screen
    (2D screen with X - Y coordinates) yes ?
    This is how I'd rotate points about an origin in C, where 160x240 is the origin
    this was to connect the points for a 3D cube, so has a faked z axis as well:
        // do pre-calculations for rotation
            theta = rotation;		// pre calculations
    	thetab = 360 - theta;
    	thetab = (3.141592 / 180) * theta;
    	ztheta = rotationz;
    	zthetab = 360 - ztheta;
    	zthetab = (3.141592 / 180) * ztheta;
    	for(cnt=0; cnt<8; cnt++) {	// 3D rotate points
            xx = xpoints[cnt];
            yy = ypoints[cnt];
            x = xx - 160;
            y = yy - 240;
            xnew = cos(thetab)*x - sin(thetab)*y;
            ynew = sin(thetab)*x + cos(thetab)*y;
            xnew = xnew + 160;
            ynew = ynew + 240;
            if (cnt < 4) {zxx = 160 + 76;} else {zxx = 160 - 76;}
            zyy = ynew;
            zx = zxx - 160;
            zy = zyy - 240;
            zxnew = cos(zthetab)*zx - sin(zthetab)*zy;
            zynew = sin(zthetab)*zx + cos(zthetab)*zy;
            zxnew = zxnew + 160;
            zynew = zynew + 240;
            xcoords[cnt+1] = xnew;
            ycoords[cnt+1] = zynew;
    The source and return data is coordinate integers, but it appears the trick you do
    is multiplying out the fractions in the formula is to occupy integers and divide later?
    Art, I see you're catching up on some reading.
    The last post was from August, 2 years ago.
    Robert (being a smart-azz)
    Aug 2003
    It's cool, cordic trig would still be a good thing to get working.
    I tried last time, and had no luck, but it's worth another shot.
    Aug 2003
    double post :O
  1. GPS decoding problems
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 25th February 2012, 11:57
  2. Replies: 1
    Last Post: - 27th June 2009, 00:33
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Replies: 20
    Last Post: - 13th May 2007, 06:10
  5. Microcontroller with 2 way paging application problem
