Epic Programmer
Results 1 to 8 of 8
Thread: Epic Programmer
    Default Epic Programmer
    Hello,
    I am using the melabs epic win programmer.
    I want to copy 1 microchip. I thought this would be easy
    but I am not sure if I am doing it correctly.
    I put the chip I want to copy in my programmer and click on read.
    I then save the hex file.
    I then put in a blank chip and load the hex file. I then click on program and
    I assume that I have copied that chip but when I read the contents it does not match
    my master chip.
    Am I doing this right ???
    skimask's Avatar
    skimask Guest
    Depends what you're trying to copy (and I think I know where this is going)...
    There is such a thing as 'hardware copy protection' built into most PICs...and it's usually pretty good for all but the most hard-core hackers, and even then it's a crap shoot as to whether or not you'll get the real information contained inside a PIC.
    Is there a way to know if the chip I am trying to copy is protected ??
    Quote Originally Posted by forzaazzurri View Post
    Ask the person who programmed it.
    skimask's Avatar
    skimask Guest
    One way is to try and read it and get garbage...or all $ff or all $00...
    What kind of microchip are you trying to copy? What part number? What company provided this chip?
    How about some information!!!
    It is a 28 pin PIC16F873,
    It is found in one of our physics equipment.
    We want to make a backup in case this one gets damaged
    as it has in the past. Students use this equipment and we
    know how they are.
    skimask's Avatar
    skimask Guest
    know how they are.
    rotsa ruck raggy...
    Probably not going to happen...
    Physics equipment is a bit vague, don't you think?
    There's a reason why these companies put copy protection on proprietary firmware...
    It was worth a shot.
    Didn't think the type of equipment was important but
    it measures the "hall effect" of certain probes and
    the manufacturer is Leybold.
  1. epic programmer to lcd
    By rdxbam in forum General
    Last Post: - 4th November 2008, 00:35
  2. epic programmer not found ---HELP!
    By dmacq in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 20:38
  3. Need the programmer EPIC software
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2007, 12:42
  4. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 13th April 2006, 00:59
  5. EPIC PLUS programmer (problem)
    By pakbasic in forum General
    Last Post: - 17th May 2005, 20:28
