I just implemented the changes Darrel suggested and IT WORKS!!! works really well! Thank you again!
I also solved my problem of the encoder routine counting by 4's, added a little asm in the
beginning that checks to see if the encoder has moved, my first bit of asm I've made.. slowly
getting a handle on things.. I also made sure to set portb<5:4> bits to outputs so they don't float.
here is the working code if anyone needs it. the connection diagram is the same as
my first post.
'Read Quadrature Encoder and display value on LCD. for pic16f876a
'setup PIC Config Fuses
    @ Device pic16F876A, HS_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF
'************************ DEFINES HERE *************************************
DEFINE OSC 20               ' set to 20mhz
DEFINE LCD_DREG PORTA       ' Set Data Registers port
DEFINE LCD_DBIT 0           ' Set starting data bit
DEFINE LCD_RSREG PORTB      ' Set LCD RS Port
DEFINE LCD_RSBIT 1          ' Set LCD RS Bit
DEFINE LCD_EREG PORTB       ' Set LCD Enable Port
DEFINE LCD_EBIT 2           ' Set LCD Enable Bit
DEFINE LCD_BITS 4           ' Set LCD 4bit Mode
DEFINE LCD_LINES 2          ' Set number of LCD Lines
DEFINE LCD_COMMANDUS 2000   ' Set Command Delay time in uS
DEFINE LCD_DATAUS 60        ' Set Data delay time in uS
clear                       'clear out variables
'*********************** CHIP REGISTER SETUP *******************************
ADCON0 = 7              ' turn off analog porta, set to digital IO
ADCON1 = 7              '
CMCON =  7              ' Turn off Port A Comparator
TRISA = 0               ' output ports
TRISB = %11000001       ' set input and output ports
TRISC = 0               ' output ports
'************************ PROGRAM VARIABLES HERE ***************************
symbol led = portc.2        ' status led
symbol led2 = portc.0       ' status led2
symbol lcdbkl = portc.7     ' lcd pannel backlight
symbol sw1 = portb.0        ' encoder switch
enc_old VAR BYTE
enc_new VAR BYTE
enc_tmp var byte
enc_counter VAR WORD
enc_counter_old VAR WORD
enc_scaler var word
'*********************** ASSEMBLY INTERUPT VARIABLES ***********************
wsave   var     byte $20 system
wsave1  var     byte $a0 system  ' Necessary for devices with RAM in bank1
wsave2  var     byte $120 system ' Necessary for devices with RAM in bank2
wsave3  var     byte $1a0 system ' Necessary for devices with RAM in bank3
ssave   var     byte bank0 system
psave   var     byte bank0 system
goto start			'skip over interupt handler
'*********************** ASSEMBLY INTERUPT HANDLER *************************
define  INTHAND myint
Asm
myint
	; Save W, STATUS and PCLATH registers
	; Not Necessary for Chips with >2k of Codespace
       ; movwf   wsave
       ; swapf   STATUS, W
       ; clrf    STATUS
       ; movwf   ssave
       ; movf    PCLATH, W
       ; movwf   psave
	;====== BEGINNING OF THE ROTARY ENCODER CODE ========
	;The Rotary Encoder is connected to PORTB
	;The A signal of the encoder connected to the PIN portB.7
	;The B signal of the encoder connected to the PIN portB.6
	;The 4 variables used are declared in the PicBasic code.
	;	enc_new VAR BYTE
	;	enc_old VAR BYTE
	;       enc_tmp VAR BYTE
	;	enc_counter VAR WORD
	   ;Read latest input from PORTB & put the value in _enc_new.
     	movf    PORTB,W
     	movwf  _enc_new
     	;Strip off all but the 2 MSBs in _enc_new.
     	movlw	0xc0    	     ;Create bit mask (bits 7 & 6). b'11000000' ?
     	andwf   _enc_new,F       ;Zero bits 5 thru 0.
        ;check to see if encoder has moved
        movf    _enc_old,W         ;move enc_old to W
        movwf   _enc_tmp           ;put W to enc_tmp
        movf    _enc_new,W         ;move enc_new to W for XOR
        xorwf   _enc_tmp,F         ;XOR enc_tmp to detect encoder movement
        btfsc   _enc_tmp,7         ;if bit is clear, encoder moved.
        goto    Continue           ;no movement exit isr
     	;Determine the direction of the Rotary encoder.
     	rlf     _enc_old,F     	 ;left shift it into _enc_old to align bit 6 of
                                 ;_enc_old with bit 7 of _enc_new.
     	movf    _enc_new,W     	 ;Move the contents of _enc_new to W in order to XOR.
     	xorwf   _enc_old,F    	 ;XOR previous inputs (in _enc_old) with latest
                                 ;inputs (in W) to determine CW or CCW.
      	btfsc   _enc_old,7     	 ;Test bit 7 of result (in _enc_old).  Skip next line
      	                         ;if it is 0 (direction is CCW).
     	goto    Up               ;Bit is 1 (direction is CW).  Go around Down
                                 ;and increment counter.
Down
     	;Decrements _enc_counter because the rotary encoder moved CCW.
	    ;Decrements _enc_counter (16 bit value), sets Z on exit.
        decf    _enc_counter,F      ; Decrement low byte
        incfsz  _enc_counter,W      ; Check for underflow
        incf    _enc_counter+1,F    ; Update
        decf    _enc_counter+1,F    ; Fixup
        movf    _enc_counter,W
        iorwf   _enc_counter+1,W    ; Set Z bit
	    ;Add here code for the CCW LED if needed.
     	bsf     _led		    ;turn on led
     	goto    Continue  	    ;Branch around UP.
Up
        ;Increments _enc_counter because the rotary encoder moved CW.
        ;Increments _enc_counter (16 bit value), sets Z on exit.
        incfsz  _enc_counter,W      ; Add one to low byte
        decf    _enc_counter+1,F    ; No carry (negates next step)
        incf    _enc_counter+1,F    ; Add one to high byte
        movwf   _enc_counter        ; Store updated low byte back.
        iorwf   _enc_counter+1,W    ; Set Z flag
	   ;Add here code for the CW LED if needed.
	   bsf     _led2		    ;turn on led
Continue
     	;Assign the latest encoder inputs (in _enc_new) to _enc_old.
     	movf 	_enc_new,W
     	movwf   _enc_old
        ; Restore saved registers
        movf    psave, W
        movwf   PCLATH
        swapf   ssave, W
        movwf   STATUS
        swapf   wsave, F
        swapf   wsave, W
        bcf     INTCON, RBIF		  ; Clear the Interupt Flag
        RETFIE                 	  	  ; Return from interrupt
endasm
'************************* PROGRAM STARTS HERE *****************************
START:              ' Main Program starts here
LCDOUT $FE,1		'Init The LCD
pause 500		    'wait for LCD to start
lcdout $FE,1,"ENCODER"	    'display splash screen
LCDOUT $FE,$C0," TEST "
high lcdbkl                 ' turn on backlight
'************************** SET DEFAULT SETTINGS HERE **********************
pause 2000		    ' just wait a bit to read splash screen
enc_counter = 1024	' set default encoder value
enc_counter_old = 1024
lcdout $FE,1,"ENCODER"  ' change display
lcdout $fe,$C0, DEC5 enc_counter
INTCON = %10001000      ' Enable PortB Change Interupts
'************************** TESTING ROUTINES HERE **************************
test:
            if  enc_counter <> enc_counter_old then 'see if value has changed
                enc_counter_old = enc_counter		'move new value to old
                lcdout $fe,$C0, DEC5 enc_counter	'display enc_counter value
                low led		                        'turn off CCW led
                low led2	                        'turn off CW led
goto test
