Writing to 1-wire EEPROM
Results 1 to 11 of 11
    Apr 2007
    Santiago, Chile
    Talking iButton
    Thanks Darrel,
    Does this mean that I don't have to use the CRC calculation system?
    Chris
    Quote Originally Posted by crhomberg View Post
    Unless you want a program that's not susceptible to spurious noise Errors, NO, you don't have to use CRC's.
    Apr 2007
    Santiago, Chile
    Red face EEPROM still not working
    I modified my program using the authorisation code but I still seem not to get my data back.
    This is my latest version (for a 16F877A)
    '* Name : eeprom.BAS *
    @ device hs_OSC, wdt_on, pwrt_on, protect_off
    DEFINE OSC 20
    ADCON1=7 ' Set all Ports to Digital I/O
    OPTION_REG.7=0 ' Enable weak PullUps
    TRISC.0=1
    TRISC.1=1
    TRISC.2=1
    TRISB.0=0
    iButton var PortD.2
    MEM VAR BYTE
    RESULT VAR BYTE[4]
    Taddr var byte[2] 'target address 2 bytes
    ES var byte 'ending offset data status
    START:
    SEROUT2 PORTB.0,16416,["START",10,13]
    'WRITE TO EEPROM
    OWOUT ibutton,1,[$CC,$0F,$00,$00] 'Write to scratchpad
    OWOUT IBUTTON,0,[$54,$65,$73,$74] 'Write characters "test"
    OWout IBUTTON,0,[$CC,$AA]
    owin ibutton,0,[Taddr[0],Taddr[1],ES] 'read back the scratchpad to get the Authorisation code
    owout ibutton,0,[$CC,$55] 'Write back the contents of the target address & E/S register
    owin ibutton,0,[Taddr[0],Taddr[1],ES] 'to allow copy scratchpad to take place.
    PAUSE 25
    'READ FROM EEPROM
    OWOUT ibutton,0,[$CC,$F0,$00,$00]
    FOR MEM=1 TO 32
    OWIN IBUTTON,0,[RESULT]
    SEROUT2 PORTB.0,16416,[RESULT]
    PAUSE 100
    NEXT MEM
    Where have I gone wrong?
    Chris
    Apr 2007
    Santiago, Chile
    Talking At Last Working
    Thanks Darrel,
    I got it right, it is now send back the letters test with this code...
    'WRITE TO EEPROM
    OWout IBUTTON,1,[$CC,$AA] 'get ready to read scratchpad
    owout ibutton,1,[$CC,$55] 'Write back the contents of the target address & E/S register
    owout ibutton,0,[Taddr[0],Taddr[1],ES] 'to allow copy scratchpad to take place.
    PAUSE 25
    'READ FROM EEPROM
    OWOUT ibutton,1,[$CC,$F0,$00,$00]
    FOR MEM=1 TO 4
    PAUSE 100
    NEXT MEM
    Thanks Chris
    Thumbs up
    WooHoo! There ya go.
    That looks much better.
    Tricky little 1's and 0's in the mode.
    Nice work!
    Apr 2007
    Santiago, Chile
    Talking That's it Babe
    I am so proud of the code I wrote for the DS1994 REAL TIME CLOCK & DS1973 EEPROM I think I must post both as they work so well and finally are relatively simple and there seems to be no sample code on the net.
    Where on the site is the place for Code Samples?
    Chris
    Careful, that feeling of "Elation" is addictive.
    Code examples always welcome.
    http://www.picbasic.co.uk/forum/forumdisplay.php?f=11
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
