PICBASIC Pro commands for using analog comparator module for PIC16F628
Results 1 to 5 of 5
    Quote Originally Posted by steng View Post
    But I have problems with the syntax used in the PICBASIC Pro.
    What problems with what syntax? Show us!
    Feb 2005
    Kolkata-India
    Default You need to manually read/write registers.
    First of all you need to configure your comparator modes through the CMCON register.
    Syntax : CMCON = %0x0xxxxx
    You would find the details from the datasheet about the different modes. Now if you are using the internal reference for your comparator then you need to setup the VRCON register to specify the reference voltage. Same way VRCON =
    Now in your application you need to poll the Comparator Output bit CMCON.6 for the comparator status. If you need interrupts then you need to setup the peripheral interrupt registers as well along with the PIE bit in the INTCON. Any change in the comparator status causes an interrupt.
    Sougata
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    see post #3 here for possible help
    http://www.picbasic.co.uk/forum/show...2459#post62459
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2008
    Smile Thanks..:)
    Thanks a lot. I'll try to read the links provided and write the commands that you all had provided. Will come back if I face any problems.
    Thanks again..
  1. PicBasic Pro Demo
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 20:10
  2. How to configure SPI in PICBASIC PRO?
  3. Timing in PICBasic Pro commands
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 11th September 2005, 01:50
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
