Fram Memory
Results 1 to 6 of 6
Thread: Fram Memory
    May 2008
    Default Fram Memory
    Je, Je, Well Some Minor Diff Like Acknowledge Signal From Eeprom Cs Signal Negate Active For Fram And For Write Command Need Bring Up And Down Between Wren And Write Command, Meybe For That The Code For Spi Eeprom Dont Work For Fram.
    Any Way Sorry For Ask, But I M Not Good In This, I Do My Best.
    I dunno.... Datasheets says it's a drop in replacement, at least for the half dozen or so I looked at (and the couple I use). Signals look the same, commands look the same...
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
  5. accessing fram memory
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 13:29
