Fram Memory
Results 1 to 6 of 6
Thread: Fram Memory
    May 2008
    Default Fram Memory
    Hi guys!
    anyone have play with Fram Memory and like to share with me code for read and write, basic or assembler welcome!
    REGARDS
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by MARGARITA View Post
    Hi guys!
    REGARDS
    FRAM as in Ferroelectric Random Access Memory?
    Look at the product numbers...look at the datasheets...look in your PBP manual... You'll see that accessing FRAM is no different than any other 24xxx or 25xxx type device.
    May 2008
    Default Fram Memory
    Thanks Skimask, Well I Read The Datasheet And There Are Some Diff. The Part Number I Buy Is Fm25256b Is Spi Interface And See Than Is Not 100% Same To Spi Eeproms, Dont Work With Same Code For Similar Spi Eeprom Part.
    skimask's Avatar
    skimask Guest
    Really? Can you tell me exactly what is different?
    May 2008
    Default Fram Memory
    Je, Je, Well Some Minor Diff Like Acknowledge Signal From Eeprom Cs Signal Negate Active For Fram And For Write Command Need Bring Up And Down Between Wren And Write Command, Meybe For That The Code For Spi Eeprom Dont Work For Fram.
    Any Way Sorry For Ask, But I M Not Good In This, I Do My Best.
    skimask's Avatar
    skimask Guest
    I dunno.... Datasheets says it's a drop in replacement, at least for the half dozen or so I looked at (and the couple I use). Signals look the same, commands look the same...
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
  5. accessing fram memory
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 13:29
