servo motor resets 16f877a
Results 1 to 40 of 86
    No current regulator.
    What he means is say one 7805 will run the PIC (7805 at best 1 amp) = low current.
    Power supply for motors are made from parallel 7805s or some other type to handle the amperage needed.
    Sep 2008
    thanks a lot i am gonna try it...
    hi Acetronics ,
    I am sure i changed code like that
    motor:
    for i=0 to 25
    PAUSEUS 20000-(T*10)
    PULSOUT PORTC.2,T
    next
    Sep 2008
    God bless you guys!
    1-I connected 9v 450ma(I hope 450ma is fine) power supply and connected two 7805 paralel and used a 470uf between vdd and vss.Mcu doesnt reset itself and works fine! But I think servo works a little bit slower than past.I dont know why? maybe changing power supply from 5.2 to 5 makes this difference...If its neccessary I can put here its video...
    2-I think I finished left-right position and wrote a new code to complete my project.I wrote this
    but That doesnt work and servo2(up-down) made some stupid moves (like vibration).Also left-right motion gets very very slower...I know I made too many mistakes.But I learned here this forum too many things that I dont know.Everybody wants to help here and I was a little suprised at the beginning of this Thread.I put my code here.
    Can you help me again? t for left-right j for up-down.I bounded "j" between 135 and 115
    My code is....
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS  4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS     8       'A/D çevirim sonucu kaç bit olacak
    DEFINE ADC_CLOCK  3       'Clock kaynağı (3=rc)
    DEFINE ADC_SAMPLEUS 100
    SYMBOL F=PORTA.0
    SYMBOL G=PORTA.1
    alta var byte
    usta var byte
    altb var byte
    ustb var byte
    sola var byte
    solb var byte
    saga var byte
    sagb var byte
    k var byte
    t var byte
    i var byte
    j var byte
    ADCON1=2
    TRISA=%00001111
    TRISB=0
    PORTB=0
    TRISC=0
    LCDOUT $FE,1
    pause 2000
    adcin  0,ALTa
    ADCin  1,usta
    adcin  2,sola
    adcin  3,saga
    T=150
    j=125
    yap:
    adcin  0,altb
    ADCin  1,ustb
    adcin  2,solb
    adcin  3,sagb
    if  ((((usta+10)*100)/(ustb+10)))>130 and (not (t>194)) then
    T=T+15
    if (((alta*100)/altb))>130 AND (not (t<51)) then
    T=T-15
    if  ((((sola+10)*100)/(solb+10)))>130 and (not (t>134))    then
    j=j+10
    if (((saga*100)/sagb))>130 AND (not (j<116)) then
    j=j-10
    gosub motor2
    gosub motor1
    LCDOUT $fe,2,#usta," ",#ustb," ",#altA," ",#altb
    lcdOUT $fe,$C0,#T,"  ",#j
    goto yap
    motor1:
    for i=0 to 25
    PULSOUT PORTC.2,T
    next
    motor2:
    for k=0 to 25
    PAUSEUS 20000-(j*10)
    PULSOUT PORTC.3,j
    next
    The lower the voltage the slower the motor.
    Are the values displayed on the LCD what you expect, are they in range?
    Most hobby servo's have a max voltage of 6v. The 450 mA should be OK for testing the servo unloaded.
    If you have it turning a platform with large weight/mass then you can easily exceed 1A. A rule of thumb, the closer you get to maxing out the capabilities of your power supply the more noise you will see, especially true with motors, which could lead to glitches. I usually don't go over 50%, if I use a 2A supply for example, I only pull 1A.
    Also, decoupling caps are a MUST! use inductors when feeding motors power with custom H-bridges. Use 0.1uf caps to filter out high frequency spikes at the motor and on your power supply to the PIC.
    Do a search online for good engineering practice guides for dealing with inductive loads. There are tons of things that will go wrong working with inductive loads, you can solve most of them with well placed caps and careful layout.
    Nick
    Sep 2008
    Yes,I think,they are....
    I follow t and j values by using lcd...
    How many extra loops is he executing between servo updates?
    Sep 2008
    thanks for the code.I am sorry it doesnt work properly..
    First I get a error and I fixed code in compiler--------pauseus 20000-((t*10)+(j*10) you forgot a parenthesis
    Servo stiil slower than usual mode
    When I worked with your code even j values got out of range...Once I saw j as 195...
    I might have another power problem like Macgman2000 said or something about code???
    You are right above.I have too many extra loops.I am stuck dont know what to do
    Quote Originally Posted by burak450 View Post
    Does it speed up if you disconnect one at a time?
    The PIC won't (i.e. shouldn't) care if there's 1, 2, or 3, or more servo's plugged in since it's not reading anything back from them.
    Try this...see if it's any faster
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS  4
    DEFINE LCD_LINES 2
    f var porta.0 : g var porta.0 : alta var byte : usta var byte : altb var byte
    ustb var byte : sola var byte : solb var byte : saga var byte : sagb var byte
    k var byte : t var byte : i var byte : j var byte : adcon1=2 : trisa=15
    trisb=0 : portb=0 : trisc=0 : pause 1000 : lcdout $fe,1 : adcin 0,alta
    adcin 1,usta : adcin 2,sola : adcin 3,saga : t=150 : j=125
    yap: adcin 0,altb : adcin 1,ustb : adcin 2,solb : adcin 3,sagb
    if ((((usta+10)*100)/(ustb+10)))>130 and (not (t>194)) then T=T+15
    if (((alta*100)/altb))>130 AND (not (t<51)) then  T=T-15
    if ((((sola+10)*100)/(solb+10)))>130 and (not (t>134)) then j=j+10
    if (((saga*100)/sagb))>130 AND (not (j<116)) then  j=j-10
    for i=0 to 25 : pauseus 20000-((t*10)+(j*10) : pulsout portc.2,t
    pulsout portc.3,j : next i
    lcdout $fe,2,#usta," ",#ustb," ",#altA," ",#altb, $fe,$C0,#T,"  ",#j
    goto yap
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
