servo motor resets 16f877a
Results 1 to 40 of 86
    Sep 2008
    Quote Originally Posted by Macgman2000 View Post
    If you have an oscilloscope look at your control pulses from the PIC to the servo as it moves. If you see that the wave form (1~2ms pulse) is wiggling around or changing amplitude then you have a power supply issue. Do as I suggested above, get a 9v power supply (AC/DC) and use TWO 7805 regulators in parallel for the servo ONLY. At the servo use 470uF across power and ground. Look at the scope again and make sure you see a "cleaned" up signal while servo is in motion.
    Nick
    I tried everything which is suggested.I changed code and put PAUSEUS before pulsout.Something wrong ,I got same error I decided to change power supply.That can cause this problem.
    I hope it will solve my problem...
    I will use two servos...(one for left-right one for up-down).I wrote the code just for left-right.I will make servos TWO if I am successful left-right position...
    Why did you say two parallel 7805? One for pic and one for servo?
    How many 7805 regulators should I use?
    Wink
    Wow...not reading very well these days...
    Doubling up on servo's will only compound your power supply quality problem.
    Why did he say 2 parallel 7805's? If you'd re-read post #39, you'll see why.
    And while you're at it, you might want to actually READ all of the advice given to you up to this point. Lots of advice being given repeatedly...seems like not a lot of it taken.
    Just a little Typo ...
    LOW Portx.y
    has to be placed before
    PULSOUT ... and not Pulsin.
    Everyone had understood ... of course !
    PS:
    are you sure ???
    Sep 2008
    I saw it now.He wrote for servo only....
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 10:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
