servo motor resets 16f877a
Results 1 to 40 of 86
    Sep 2008
    i should repeat that=Lcd brightness doesnt change at normal work. when servo moves than it goes high or low...
    my power supply is that.
    switching adapter
    input:ac 100-240V-50hz 0.36A
    output:dc 5v--2.5A
    and my program is that
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS  4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS     8
    DEFINE ADC_CLOCK  3
    DEFINE ADC_SAMPLEUS 100
    SYMBOL F=PORTA.0
    SYMBOL G=PORTA.1
    alta var byte
    usta var byte
    altb var byte
    ustb var byte
    ADCON1=2
    TRISA=3
    TRISB=0
    PORTB=0
    TRISC=0
    LCDOUT $FE,1
    pause 4000
    adcin  0,ALTa
    ADCin  1,usta
    t var byte
    i var byte
    T=150
    yap:
    adcin  0,altb
    ADCin  1,ustb
    if  ((((usta+10)*100)/(ustb+10)))>135 then
    T=T+15
    if (((alta*100)/altb))>135 then
    T=T-15
    gosub motor
    LCDOUT $fe,2,#usta," ",#ustb," ",#altA," ",#altb
    goto yap
    motor:
    for i=0 to 25
    PULSOUT PORTC.2,T
    PAUSEUS 20000-(T*10)
    next
    May 2008
    Italy
    Check power supply wiring, especially the connector, install 1000 uF 16V electrolytic capacitor and 10 nF on your pic power pin
    For grins, try changing your BYTE values to WORDs and see what happens.
    Might be overflowing the byte values somewhere killing the program somehow someway.
    Question Some ideas to look for details ...
    Hi, Burak
    I'm curious to know which testboard you use ...
    16F877A , LCD on PortB ... that sounds quite familiar.
    So, the question is ... Where do you ( geographically ) take the servo 5v supply from ???
    Use a separate power supply for your servo.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2008
    Bruce thanks for advice,i tried million times but couldnt connect separate supply correctly.I think you mean opto-isolotor circuit.Do you suggest any opto-isolator circuit??
    Some guys said i dont need this circuit.I am confused now.
    Acetronics,I took 5v supply to servo from same source where I took power to pic.I mean servo and pic is feed same source...
    Feb 2005
    Kolkata-India
    Default Monitor the PCON register
    16F877a has got a Power Control Register (PCON). Section 14.10 page 151 in the datasheet.
    In the top of your code just after you initialize the LCD. Read the PCON into some variable and display it on the LCD for say 5 seconds. Note it down just after a reset. This may help decide the cause of the reset---> Brown Out, WDT, MCLR etc.
    Also make sure that your RB3 (Pin 37) is not floating. It is the LVP pin and noise on that can trigger the ICSP mode.
    Just for information on the opto part you can use a TLP250 optocoupler (works upto a few khz) which has got a totem-pole output. So you drive the LED and get a 0-1 on the output. I use it mainly for my IGBT driver needs.
    Sougata
    You should not need an opto, but you may want to include the series resistor shown in the .PDF Alain linked to.
    A separate power supply for the servo is a good idea, but you need a common ground connection between the two power supplies.
    Most hobby type servos will work fine with a DC supply of ~4.8 to 6Vdc. I normally use a set of 4 x D cells. Just connect the ground leg from your batteries to the ground leg of your regulated supply for the controller.
    If you use another regulated supply for the servo, make sure it can handle the servo load current. A servo can draw quite a load. Some up to 1A or more. Having this load on your primary supply can drop voltage and cause a device reset. With separate supplies you shouldn't have this problem.
    -Bruce
    tech at rentron.com
    Lightbulb
    Ok, Folks
    I've got it ...
    Servo driving values on C.2 go out of the nominal 0.8 - 2.2 ms range OR Pause between pulses goes wrong.
    Servo bumps on its mechanical stops ... or the amp doesnt like the pause !!!
    That's all !
    Sep 2008
    Acetronics,
    Can you explain it more clear,i dont get what you mean.Is there any solution on your mind?
    Lightbulb
    Hi, Burak
    The only solution is for you to verify you send correct signals to your servo ...
    800 to 2200 µs @ 35 - 50 Hz ... only allowed.
    Nothing more or less to say !
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
