Ethernet & ENC28J60
Results 1 to 3 of 3
    Jan 2008
    Dublin, Ireland
    Default Ethernet & ENC28J60
    Hey All
    Is anyone familier with a component that can be used as the tx rx filter on the TPIN+/TPIN- and TPOUT+/TPOUT- pins of the ENC28J60, There is a diagram on page 9 of the data sheet.
    Its a centre tapped pulse transformer of some form that I require, if anyone is familier with this and knows a part number and or supplier id realy appreciate the help.
    All the best
    Tony...
    ichilton's Avatar
    ichilton Guest
    I think the easiest is to use an RJ-45 socket with "integrated magnetics" - that contains all of those components and 2x LED's so you only need the 49.9R resistors and a ferrite bead.
    See here:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290270492935
    (for history sake when the above link doesn't work any more, the auction is for "Ethernet 10/100Base-TX RJ45 w LEDs & Magnetics Enc28j60" from the seller micro4you - the datasheet is here: http://www.micro4you.com/files/conne...RJ-0XX-PPT.pdf)
    They also do a built ethernet module and the schematic is here - this shows how to use those jacks - everything in green is inside the jack:
    http://www.micro4you.com/files/enc28j60/ENC28J60.pdf
    Ian
    elektronik's Avatar
    elektronik Guest
    Default Ethernet
    hi The sample code ?.
    thanks
  1. PIC 18F97J60 and Ethernet
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 16th April 2008, 12:51
  2. serial data over ethernet?
    By lester in forum Serial
    Last Post: - 22nd November 2007, 08:29
  3. Microchip Ethernet controllers
    By Philip in forum Documentation
    Last Post: - 2nd November 2007, 01:30
  4. Ethernet Communication
    By Christopher4187 in forum Forum Requests
    Last Post: - 1st June 2006, 17:24
  5. ethernet to rs-232
    By maus in forum mel PIC BASIC Pro
    Last Post: - 18th April 2006, 17:44
