LVP will not turn off
Results 1 to 3 of 3
    Feb 2010
    Default LVP will not turn off
    Using PBPP and EPIC programmer and having some trouble with 16F887 part. Tried changing to _LVP_OFF in 16F887.INC and found it never "takes," even though other settings I make there work fine. That is, when I bring up EPIC to program the part, LVP is enabled. So also tried turning it off in my code:
    __CONFIG _CONFIG1, _LVP_OFF
    Again though LVP stays enabled when any other settings I make do take. Also tried disabling LVP using the EPIC programmer drop down list method. Seems to work, but if I read back in, LVP is enabled.
    I got around it by not using the RB3/PGM pin and instead tying it low. Everything works fine. However, the behavior bugs me (also I'd like to use that pin for IO).
    Any hints as to why this is happening are appreciated.
    I do not have an epic. But I hear there is a setting in the software to tell the epic not to set the fuses and let the fuses be set in code.
    Have you tried that ?
    Feb 2010
    Default Re: LVP will not turn off
    Thanks I will check into that possibility. However it does set other fuses I've tried. Only LVP is refusing to change. That's the maddening part -- everything else works as expected.
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  2. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 23:27
  3. Help with PIC project
    By davekav in forum General
    Last Post: - 18th April 2008, 00:15
  4. Interface for 16f818
    By davekav in forum Serial
    Last Post: - 17th April 2008, 12:33
  5. Button problem driving me crazy!! Please help!
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 20th November 2007, 15:46
