DS1994 i-Button Real Time Clock
Results 1 to 11 of 11
    Apr 2007
    Santiago, Chile
    Question DS1994 i-Button Real Time Clock
    I have started a project using this clock and successfully programmed the time and date using the 1-wire protocol. There don't seem to be any extra application notes from Dallas/Maxim on this chip and the manual is very skimpy. All I need is to set it up as an alarm clock. It has 3 alarms inside, each with it's register but I cannot see hoe the registers are set out or how to program them & then read them to see if the alarm flags have been triggered.
    I saw a post a while back with someone programming the device but he also only got to where I am now.
    Any ideas?
    Chris
    Chris... is this for your PLC project?
    If it is, you're thinking way too complex...
    Example, you need the PIC to stop your PLC roughly 90 days after installation... the installation runs 24/7, so have the PIC simply keep time (with a Pause 1000) and increment EEPROM every hour. Once a day (on the 24th hour) increment EEPROM days counter. At 90 Days stop the process... you don't need great accuracy... if the PIC loses or gains a day in the process it won't matter. If the unit is switched off, too bad you could lose 59 minutes that weren't stored in EEPROM - but who cares? All you want to do is kill the equipment at some future point give or take a day or two... you could accomplish all this with a PIC16F628 running on internal Oscillator!
    PS - DS1994 is obsolete!
    Apr 2007
    Santiago, Chile
    Default Real Time Clock
    Melanie,
    I need to keep the system running for at least 6 months +- a day or so.
    The PLC is far from me (as in another country) so it is not easy or cheap to reset it or change the setting. My original idea was to have a DS1994 with it's alarm set at 6 months and another without an alarm. When the customer pays I ship a new DS1994 without alarm to them. As long as the clock ticks all is happy, if it gets removed for more than maybe an hour it will shut down too.
    Maybe that is too complicated.....
    Would two ibutton eeproms with different codes do the same thing if the PIC was the clock and I would have to ensure that that PIC clock works for years, it cannot fail after the customer has paid.
    Chris
    Apr 2007
    Santiago, Chile
    Melanie,
    After thinking about it after my last post I thought maybe a good solution is a small PIC, a iButton eeprom with a code with a date and another that just keeps the output on with a small realtime clock inside which I can set before sending the switchboard off. (maybe a DS1302) I will still have the ibutton exchange system but without having to set the DS1994 alarm which I cannot get around. (Is the DS1302 relatively accurate over a year? +- 1 day)
    Chris
    I'm not on the forum every day Chris, yesterday was an exception.
    Firstly, with the DS1994, I've never actually played with one. That code I wrote with Ralph was 100% on paper with detail just from the Datasheet. I would assume, that you write to the Real-Time Alarm Register exactly the same way as you would for the Clock Register. Try it, set the time, advance five minutes in software and Set the RTC Alarm Register. Then just wait and continuously poll the Alarm Flag and see what happens five minutes hence.
    Secondly, with regard to the DS1302... I've only used the DS1307. The accuracy is about +/- 20 minutes in a year (with a junk crystal). Batteries (CR2032 type) I've never had run out, some units have been in service for over five years.
    Thirdly, I don't think you need a clock at all. A PIC will do everything 100%. What you have is a simple application (I know because I've done something very similar with a time delay of about 14 months!!!!).
    Apr 2007
    Santiago, Chile
    Smile Real Time Clock
    Thanks Melanie for your time,
    I can see your point of not needing a rtc. You mentioned using PAUSE 1000 for my seconds count, don't you think this will be "very" inaccurate if the pic is also saving to eeprom, talking to the PLC etc. Will it not be better to use the clock in the PIC to generate interrupts with ON INTERRUPT to keep the counting more precise. I need it to try not to loose a day in 6 months to a year.
    Chris
    > talking to the PLC etc...
    Not seeing the big picture what else the PIC has to do it's difficult to comment.
    If it's just ensuring a Power-Up sequence to the PLC, keep rough time and maintaining a HPWM value then there's no sweat. Of course you need to ensure the equipment is on 24/7 (or otherwise provide a Battery). As soon as you put a clock-chip on a PCB, the punter starts to wonder Why? What is it for? A PIC on it's own however you can make any number of excuses why it's there.
    Why is it so important to keep accurate time? If the guy pays his bill it's OK. If he doesn't, then to have it die exactly at 9pm on Wednesday 27th May 2009 (taking into account Daylight Savings time as well) is pretty irrelevant. So +/-up to 24 hours is neither here or there.
    This is what gets me about the ol' Muslim Prayer times... like God is going to get the hump if you miss it by a couple of minutes!
    Apr 2007
    Santiago, Chile
    Melanie,
    I don't think I need Muslim prayers.
    I agree, I don't think I really need such high accuracy (about a day in 6 months is OK)
    Do you think I can get that using the PAUSE or the TIMER?
    Chris
  1. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 04:52
  2. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 16:05
  3. Real time clock... what a headache!
    Last Post: - 8th June 2006, 21:56
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
