The only problem I can see is that your LED modules will
have to produce the same light intensity. This is going to be
important when the LED modules are mounted close to each
other and therefore you can compare the intensity of the light.
The quality of the used LEDs and components will make the difference.
Life duration of high efficiency LEDs is an important consideration.
Best regards,
Luciano
