Usually when i have the need for transistors i also have the need to dot them around the PCB so they can be squeezed into small areas. Having an array of them in a DIL package may be smaller in all but it cant be split up to fit into the little spaces i have spare. As it happens ive redesigned this circuit and all the transistors are in a line but i do only need 4 of them.
Normally a TO220 package wouldnt be a problem especially if i need a lot of current but this time i only need 200mA and i dont have the vertical space for them. There will be 2 PCBs that are only 10mm apart. One of the voltage regulators will be soldered to the underside of the PCB and both of them will be folded over to be parallel with the PCB.
There will be a bigger version of this light with more LEDs but for this one im limited with space. Ive redesigned the circuit to use 4 of those transistors Luciano recommended and they all fit on fine
