The MPSA14 is a Darlington transistor. (See datasheet page 1).
http://www.rapidonline.com/netalogue/specs/81-0142.pdf
The Darlington transistor (often called a Darlington pair) is a semiconductor
device which combines two bipolar transistors in a single device so that the
current amplified by the first is amplified further by the second. This
configuration gives a high current gain and can take less space than two
separate transistors because the two transistors can use a shared collector.
The 100k resistor can be omitted if you can afford to have the LEDs in an
unpredictable state during the initialization of the microcontroller.
The 10k resistor must be present.
Best regards,
Luciano
