Choosing a transistor
Results 1 to 40 of 52
    Jun 2007
    Mansfield, UK
    Luciano, I have seen the max forward voltage. I thought it meant on average.
    Im using more LEDs now. Ive re-arranged the circuit a little so that theres hardly even room for the 2 screws and ive got 48 LEDs on it. Its a bit less cramped on the track side because each LED only has 2 legs instead of 6. There are 12 LEDs in each color. The datasheet says 4.2V max for the white ones. If i have groups of them in parrallel (4 LEDs in each group) and connect the groups in series then i should end up with 4V per LED. I think that means they would only use 150mA per color too
    Italy
    The power dissipated in a MOSFET is the voltage across it times
    the current going through it.
    The voltage across the MOSFET when it is on will be the
    resistance of the MOSFET, Rds(on) times the current going
    thorough it.
    A MOSFET IRLR/U2905 has a on-resistance of 0.027Ω.
    Power dissipated by the MOSFET case when you have 2 Amps of
    current going thorough it will be: (2A = 100 LED's 20mA).
    P = 2A^2 * 0.027Ω = 0.108 Watts.
    (No problem without heatsink).
    Best regards,
    Luciano
    Jun 2007
    Mansfield, UK
    Quote Originally Posted by Luciano View Post
    Thats good news then. I dont even have room for TO220 packages. Theres no way i could get a heatsink to fit in there. Im not even using a heatsink for my voltage regulator since it never gets remotely warm with just a PIC chip and a MAX485 connected.
    One thing i dont understand is how you know that 0.108W means you dont need a heatsink
    Italy
    Quote Originally Posted by The Master View Post
    From the datasheet. The thermal resistance junction-to-ambient is for when
    there is no heatsink.
    IRLR/U2905 datasheet:
    http://www.irf.com/product-info/data...a/irlr2905.pdf
    The thermal resistance Junction-to-Ambient of an IRLR2905 is 110 °C/W.
    Its operating junction temperature range is -55 to + 175 °C.
    Example ambient air temperature = 45°C:
    175°C − 45°C
    __________    =  1.18 Watts
       110°C/W
    With an ambient air temperature of 45°C, without
    heatsink an IRLR2905 can dissipate 1.18 Watts. (Absolute Maximum).
    Best regards,
    Luciano
    thorough it.
    Of course that also assumes you are driving the MOSFET 'hard enough' (i.e. large enough Vgs vs. Vds) to get that low Rds(on).
    If you come up a bit short on the Vgs, the Rds(on) could be much higher.
    It's always something, ain't it?
    Italy
    The power MOSFET IRLR/U2905 has logic-level gate drive and
    therefore you don’t have to worry about that. Just try and
    measure the voltage drop.
    Jun 2007
    Mansfield, UK
    Ive been looking at the datasheets again and as far as i can see the LEDs in total will use at most 200mA per color. Ive been trying to find a suitable mosfet to control them but im still having a bit of trouble. There is a category on rapid called "TO-220 Logic level power MOSFETs N-Channel". I dont want a TO220 package but i thought i would look at the datasheets anyway because they seem to be exactly what you recommended. I still cant seem to understand this gate voltage. Even the logic level one im looking at says "Gate-source voltage ±18V". There is also a "Gate Threshold Voltage" That says 2.5V. Is that what i should be looking at?
    I almost got the heatsink bit. skimask confused me a bit though. I have a rough idea of how hot certain components will get with a certain load on them but usually i just put my finger on it to test. That seems to work well except for when i shorted a regulator out once... ouch :P
    So, It looks like the only logic level mosfets that rapid do are in a TO220 package. I want to look through the rest of the mosfets to see if any will do the job but it looks like most of them are for audio circuits
    Edit: Would the 2N7000 N CHANNEL MOSFET be suitable?
    Italy
    Use that:
    Datasheet MPSA14 DARLINGTON TRANS NPN:
    http://www.rapidonline.com/netalogue/specs/81-0142.pdf
    Best regards,
    Luciano
    Jun 2007
    Mansfield, UK
    Yes that is usefull. I think im using the type of regulators they mentioned (the bad ones). The plan was to use a 12V one for the LEDs and a 5V one for the rest of the circuit. It will help picking the correct resistors for the different colors too (each color uses different amounts of amps and volts)
    The lights im making are actually like spotlights so i would have thought a 15 degree angle should be fine. There is a directivity diagram in the datasheet Im not sure if thats what you mean. I can try and compare it with some other LEDs i already have but the best thing is probably to buy a few and turn them on
    I do have a multimeter and now a PC oscilloscope. I had to use them a lot while getting a test circuit working with the origional multicolor LEDs
    I see what your saying about the transistors. I did have some running with the old LEDs though and they seemed to be fine. They did start getting a little hot so i turned my PSU down a little. They cooled back down and continued to run for about 2 hours with no noticable temperature increase. I will order some mosfets instead though just to be on the safe side.
    I think what im going to do is try to figure out exactly what mosfets and resistors i need etc for those LEDs then buy a few and see how they work
  1. Replies: 24
    Last Post: - 7th November 2008, 05:41
  2. Power Transistor / Mosfet Suggestion?
    By exelanoz in forum General
    Last Post: - 13th July 2008, 09:51
  3. PIC driven transistor - smoothed signal edge - why?
    Last Post: - 17th June 2008, 09:58
  4. LED with Transistor
    By mimi_deviL in forum Schematics
    Last Post: - 9th February 2008, 09:03
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
