Choosing a transistor
Results 1 to 40 of 52
    Jun 2007
    Mansfield, UK
    Default Choosing a transistor
    Hi, How do you go about finding the right transistor for the job? Is there somewhere that lets you search based on certain values like the parametric search at micrchip.com?
    One quick thought...I usually go to www.digikey.com, whether I end up buying from them or not is another story...
    Type 'transistor' in the search box, pick the type of transistor (example Transistor BJT Single under Discrete Semiconductor Products), then narrow it down based on the lists provided. Do it for MOSFETs, chips, resistors, whatever.
    I'm sure Digikey isn't the only company that has a 'drill-down' type system for figuring out what a person wants to buy. And I'd be willing to bet that if you know a semi-conductor manufacturer (i.e. Fairchild, Motorola, etc), you'd probably be able to do the same thing at their websites.
    Jun 2007
    Mansfield, UK
    I use Rapid for components. They do have a kind of drill down to find things but its not got anything like that site you linked me to. I did a quick search but i cant seem to find any transistors that rapid sell. Maybe im looking for the wrong things though. Now i can find the formulas i need and put the results into that page and hopefully find what i need and hopefully i wont end up using NPN transistors again where i need PNPs
    Oct 2003
    Australia
    If your desiging a circuit from scratch - then chosing the right transistor is a bit of a black art.
    That said, if you have an idea of the operating voltage and current draw you can narrow your search down.
    Probably best to trawl the net for some circuits (similar to your idea) and copy that.
    If your replacing a stuffed transistor - change it with the same or get your hands on a transistor comparison tables book to find an equiv.
    Squib
    Quote Originally Posted by Squibcakes View Post
    No kidding! Sometimes it's black enough that you end up with nothing but that... Black art all over your circuit board!
    Sep 2008
    Seattle,WA
    I think a question is what you want to do with the transistor. If for driving something, there are tons of IC drivers for driving high or low and very high current DC or AC loads - even opto-isolated drivers. There are even opto isolated triacs (I've used them to directly drive up to 25 watts of lights for disco effects! 64 channnels for $1 a channel!)
    So fill us in and maybe everyone can help with a driver IC or how to select your transistor.
  1. Replies: 24
    Last Post: - 7th November 2008, 05:41
  2. Power Transistor / Mosfet Suggestion?
    By exelanoz in forum General
    Last Post: - 13th July 2008, 09:51
  3. PIC driven transistor - smoothed signal edge - why?
    Last Post: - 17th June 2008, 09:58
  4. LED with Transistor
    By mimi_deviL in forum Schematics
    Last Post: - 9th February 2008, 09:03
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
