PIC & Profibus DP
Results 1 to 6 of 6
    Apr 2007
    Santiago, Chile
    Default Profibus too complicated
    Thanks Melanie,
    The device I'm making is to ensure that the customer pays, we have instances when we installed the system after they pay 2 thirds of the price and then never complete the payment, continuously making up new problems to avoid paying. This is a cruel way but only way to stay above water.
    I think your way makes good sense but the PLC programmers there are not "so thick", they will see the LEDs showing the digital inputs and note them and then replace my unit with direct connections. I thought maybe analog values using a voltage to 4-20mA generator. Do you think this will be reliable enough. I cannot have this thing stopping without reason or I am toast!
    Chris
    I assume you are programming the PLC?
    Say you have four inputs... at Power-ON the PIC sets a combination, the PLC looks at this combination, checks it is valid, pulses an I/O to the PIC which then changes the combination, the PLC checks this is also valid, pulses the PIC which now sets a third combination. Finally the PLC verifies this and moves on. If this third combination (which thereafter remains constant) changes, the PLC shuts down. The only way to restart is to Power-On again. So the PIC and PLC exchange three sets of Data at Power-On which have to be valid (you can do this with TWO I/O's and a 'pseudo' Serial chain between the PIC and the PLC).
    If the PIC times-out (ie they've not paid their bill), all you do is change the data interchange to something that the PLC will find invalid in the first or second verification.
    Another (single I/O) way is to have the PIC perform HPWM Output... say to output a nominal voltage of 4v. The PLC looks to check that the voltage is in the range 3.75-4.25v. If it is outside this range, it can shut-down. All your PIC needs to do is to alter this voltage outside the 'good' band in ordder to shut-down the PLC. To prevent a techie simulating this voltage, at Power-Up, make it go 5v, 0v, 4v in a predetermined time period which the PLC will look for and do a different combination if they've not paid their bill.
    Apr 2007
    Santiago, Chile
    Talking Great, great, great
    You really are something Melanie, you just put it so simply. I think I will use the analog method.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
