Synchronous Comms between Pics
Results 1 to 2 of 2
    AndyP's Avatar
    AndyP Guest
    Default Synchronous Comms between Pics
    Hi.
    I am trying to establish a mini data network where there is one master PIC that sends commands to other slave Pics in my latest project, and I wanted to use asnyc comms to achieve this, mainly because of speed. The slave pics will be doing things like software PWM, but a small gap in the pulsetrain won't matter. (Its actually for an RC servo).
    I don't seem to be able to achieve this with SHIFTIN and SHIFTOUT because SHIFTIN still acts in master mode whereby it provides the clock source. How have people achieved this in the past? Is it a case of "rolling your own" input routine?
    Andy P.
    AndyP's Avatar
    AndyP Guest
    Finally found out that you do need to roll your own. Using bits of code that I found on here and on the old email archive, I come up with this for transmitting one byte:
    TXBYTE:
    FOR COUNTER = 0 TO 7
    DAT_SCU = TMPBYTE.7
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    CLK_SCU = 1 ' Make clock go high after 8 instructions.( = 32 x 125ns = 4us wait)
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    CLK_SCU = 0
    TMPBYTE = TMPBYTE << 1
    NEXT COUNTER
    And for receiving it:
    RXBYTE:
    FOR Counter = 0 TO 7
    WHILE CLK = 0 : WEND 'Wait for clock to go high
    TMPBYTE.0 = DAT 'Assign bit value on datapin to byte variable
    IF Counter < 7 Then TMPBYTE = TMPBYTE << 1
    WHILE CLK = 1 : WEND 'Wait for clock to go low before re-entering loop
    NEXT
  1. Communicating between two PICs over DC bus
    Last Post: - 7th May 2009, 12:57
  2. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  3. Synchronous Comms
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 15:21
  4. Programming Pins of PICs?
    Last Post: - 15th August 2007, 18:59
  5. 256 Pics Communicate to 1 Master Pic
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 15th July 2004, 13:11
