LCD automatic management?
Results 1 to 10 of 10
    Default LCD automatic management?
    Greetings,
    I finished one more aplication but i just dont like the visual outcome on my LCD.
    I have a common 16x2 LCD and i have a screen where i have on the first line the Max value, Average value and minimum value indications and for the second line shows the values.
    The problem is that with 3 digit values the spacing is correct, but with 1 digit values the spacing is way off ( please see attached pictures ).
    There would be nice if the values were always under the names.
    Is there a simple way or making it automatic to manage the screen according to the value sizes ?
    Looks like you are just putting a "space" between the values on the second line.
    The first position on the second line is 80. If you always want something to start at the second position then tell it to start at 80+2., then the nest set of data could start at 80+7 and so on.
    The only problen is if the data is to long to fit in the space provided.
    Hi mackrackit,
    thanks for your help
    The values will only have 3 digits max.
    This is the code i used:
    lcdout $fe,2," MAX  AVG  MIN  "
    lcdout $fe,$c0," ",DEC MAXIMO,"C ",DEC MEDIA,"C ",DEC MINIMO,"C     "
    I'm not able to try this now, but your sugestion is something like this ?
    lcdout $fe,81,DEC MAXIMO,"C"
    lcdout $fe,87,DEC MEDIA,"C"
    lcdout $fe,8c,DEC MINIMO,"C"
    My best regards
    Rui
    CORRECTION... I said second line 80... C0 is correct.
    So
    lcdout $fe,C0,DEC MAXIMO,"C" 'Starts at fist space
    lcdout $fe,C6,DEC MEDIA,"C"    'Starts at space 6
    lcdout $fe,CB,DEC MINIMO,"C"  'Starts at space 11
    thanks
    So
    Ahem: 80 <>$80
    Ahem: 80 <>$80
    OOPPS
    Thanks Joe
    lcdout $fe,$C0,DEC MAXIMO,"C" 'Starts at fist space
    lcdout $fe,$C6,DEC MEDIA,"C"    'Starts at space 6
    lcdout $fe,$CB,DEC MINIMO,"C"  'Starts at space 11
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
