i'm in trouble...help me please...
Results 1 to 13 of 13
    Aug 2008
    Unhappy help me in coding for xin & xout for x-10 PLC
    i want to transmit data using x-10 powerline communication and receive the data at the receiver.but i don't have an idea how to do it.basically i just want to turn the LED at the receiver by just push the button at the transmitter.that all.please someone help me...
    Look at the XOUT command in the manual and look at the info Dave Houston has on his site http://www.davehouston.net/
    Should get you started.
    Aug 2008
    yes, i've look a the xin & xout command but i can't understand.how can i timing the 120khz to burst at each zero crossing???help me please.
    Quote Originally Posted by texas5 View Post
    XOUT takes care of this for you.
    From the manual:
    XOUT only processes data at each zero crossing of the AC power line as received on ZeroPin. If there are no transitions on this line, XOUT will effectively wait forever.
    Do you have an X10 module?
    Aug 2008
    i refer to application note from microchip(an236) with a little modification(use only push button not push button + LCD).does xout & xin in the picbasic are x-10 driver.if so,that means i only have to command the xout & xin because i only want to "turn the LED at the receiver by just push the button at the transmitter".can i do that???
    XIN/XOUT receives or sends commands from/to the X10 module.
    From the manual:
    XOUT is used to send control information to X-10 modules. These modules are available from a wide variety of sources under several trade names. An interface is required to connect the microcontroller to the AC power line. Either the PL-513 for send only, or the TW-523 for two-way X-10 communications are required. These devices contain the power line interface and isolate the microcontroller from the AC line. Since the X-10 format is patented, these interfaces also cover the license fees.
    Cool
    Hi, Texas
    It would be Very Kind from you to give the subject of your "troubles" in the Thread title ...
    Thank you
    Unless I'm mistaken, doesn't using the XIN/XOUT commands remove the end user from having to worry about any of the hardware functions, other than the actual X10 modules themselves?
    Aug 2008
    ok.thanx a lot guys...
    Aug 2008
    and one more thing.can someone guide me where do i need to start the coding.my main idea is...
    transmitter:
    1.press push button
    2.detect each zero crossing(i don't know how to play with the delay)
    3.burst 120khz(i don't know how to play with the delay)
    receiver:
    1.detect each zero crossing(i don't know how to play with the delay)
    2.get started data (in this case, bit 1)
    3.get another data (in this case, bit 1 or 0)
    4.stored data
    5.called back the data(if 1 1=on led...if 1 0=off led)
    i really hope someone can guide me....please....
    Are you going to use off the shelf modules or try to make you own?
    I will advise against making your own modules.
  1. trouble with microcode loader
    By meho in forum mel PIC BASIC
    Last Post: - 9th August 2012, 14:39
  2. Replies: 10
    Last Post: - 2nd May 2009, 07:42
  3. Trouble with PIC12F683 - GP0 GP1 as inputs
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 04:32
  4. Trouble using int. osc. On 18f2455
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 15th June 2007, 10:35
  5. 12F629 Trouble
    By shahidali55 in forum General
    Last Post: - 18th May 2007, 09:22
