HELP ME, SMS controlled relay using PIC
Results 1 to 15 of 15
    Sep 2008
    Default HELP ME, SMS controlled relay using PIC
    hello everyone,
    my project is this, a message should trigger a relay, i only need one relay for an alarm.
    my problem is that i don't know how to read the message using PIC and what AT command should i use, what PIC should i use to read the SMS, what cellphone should i use? to be honest i have only a little experience about PIC.
    so please could anyone help me realize this project. any tutorial or guide will be great help for me to understand on where should i begin. i also need a circuit diagram and program code if possible.
    thanks in advance.
    May 2008
    Italy
    Read the below given link it will be a good start
    http://www.developershome.com/sms/ho...dSMSFromPC.asp
    Sep 2008
    Default aratti
    thanks for the link, ill already read it. it gave me an idea on how to communicate the cellphone using PC but i need codes in using pic.
    What do you mean by 'codes in using pic'? A ready made program?
    Please have a look at the link:
    http://www.picbasic.co.uk/forum/foru...c&daysprune=-1
    and specially:
    http://www.picbasic.co.uk/forum/showthread.php?t=8493
    http://www.picbasic.co.uk/forum/atta...9&d=1145772480
    (credits to charudatt)
    P.S. Next time give more details, like your PIC type, your IDE and you up to this moment program you have written.
    Sep 2008
    and specially:
    yes, if possible can u give me a ready made program. i seen a lot of sample program in the forum but really i can't understand the initialization, and how to send AT commands using PIC. i already tried sending AT commands using hyper terminal and it works and now my problem is on how to use the PIC to send AT commands. thanks for the links. hope you can help me.
    Quote Originally Posted by pazko1125 View Post
    Did you even look at the links above? Looks to me like 'ready made'...
    Maybe you should start off by making a PIC do something simple like making an LED blink or something along those lines before trying to tackle sending/receiving serial port data....much less trying to talk to a cell phone. I mean... How far into PICs are you? How much stuff have you built? Have you answered any of the questions Ioannis asked two posts above? We don't know what you're dealing with...
    Sep 2008
    i don't really have idea on what PIC should i use in this project. i have used a PIC16F84a before but only for blinking and if statement for the program. i haven't done project dealing with strings and variables yet. so can u give some sample coding or tutorials to study with. thanks.
    Totally up to you...
    It's a start...
    Maybe you should...
    Question is....Can you use the Search function near the top of this page? Or just maybe troll the forums for some pre-made code...
    Sep 2008
    It's a start...
    Maybe you should...
    yes, i've seen charudatt's code. is it also applicable to mobile phone like sony ericson t610 bec it uses a modem and i can't find a modem here. thanks
    My suggestion would be to find a phone with AT-command support like many Nokia's and other brands do. Erricson or Siemens of the old school I recall use only PDU format.
    May 2008
    Italy
    Since you said to have already tested a working system using hyperterminal, you should know the basic AT commands!
    First of all you will need a phone that is capable of text mode. You will easily check your phone
    if is capable of text mode, connecting it to your PC and with hyperterminal send the following AT command "AT+CMGF=1" if answer will be "OK" then you can have a chance to complete your project, if the answer you will obtain will be "ERROR" then your phone use only the PDU mode which need a lot of decoding before you can read the message received. So search a phone that has the text mode.
    Before to connect the phone to any PIC device you need to interface the RS232 signal to a TTL in/out this is easily solved using the MAXIM 232
    When your hardware is ready you should program your pic using the same AT commands you have used experimenting with hyperterminal as you said.
    Sep 2008
    Quote Originally Posted by aratti View Post
    thanks. yes it support text mode.
    if i send this command using PIC, how can i get the message? do i have to make a variable for it or is it already on the memory?
    SEROUT2 TXPIN, BAUD, ["AT+CMGR=1"]
    +CMGR: "REC READ","+31625044454",,"07/07/05,09:56:03+08" 'phones reply
    Test message 1
    can u give a circuit diagram for that. i have circuit diagram here from edaboard.com and i don't know if it will work.
    http://www.edaboard.com/ftopic328792.html
    May 2008
    Italy
    yes you will need variables to store the modem answer!
    Remember to add 13 at the end of the at command SEROUT2 TXPIN, BAUD, ["AT+CMGR=1",13]
    schematic for you project is rather simple because you will use only one pin for output to drive your rele. Since the rele will work at 12 volts and it will require minimum 100 mA you will use a transitor to interface it. I suggest you to use one ULN2803 which is an array of 8 transistor ready for ttl interfacing so you can connect it directly to your pic. Connect all the array, perhaps later you will need an extra rele. Check the data sheet for the other connections.
    In writing the software you will need to set up your phone first of all.
    ReadTxt:
    SEROUT TXPIN, BAUD, ["AT+CMGF=1",13]
    SERIN RXPIN, BAUD,5000,ReadTxt, ["OK"],Data
    if Data=10 or Data=13 then JumpOut
    pause 5000
    goto ReadTxt
    JumpOut:
    ModemOn=1
    This routine will set your phone in text mode and will set the variable ModemOn to 1. This is very important because when you will switch of your system I will find this variable very useful.
    Second thing you will net is to set the memory place where to read the incoming messages
    SEROUT TXPIN, BAUD, ["AT+CPMS=MT",13]
    Pause 10000
    Now you are ready to check your phone for the presence of sms
    Loop:
    SERIN2 RXPIN, BAUD,5000,Loop, [wait("^SMGR:"),str Data\5
    if Data[1]=48 and Data[4]=48 then Loop
    SERIN2 RXPIN, BAUD,5000,NoSms, [wait("XYZ"),str Data\9
    do here your decoding and actions
    NoSms:'remove SMS
    SEROUT2 TXPIN, BAUD, ["AT+CMGD=1",13]
    Pause 1000
    goto Loop
    Hope it will help
    Alberto
    Sep 2008
    alberto,
    thank you for the coding. just one favor, can you put some comments on this coding. i think it stores the mesage it receive but i can't configure out how it works. thanks again.
    Loop:
    NoSms:'remove SMS
    Pause 1000
    goto Loop
    May 2008
    Italy
    Loop:
    SEROUT2 TXPIN, BAUD, ["AT+CMGF=1",13] (here you call for a sms)
    SERIN2 RXPIN, BAUD,5000,Loop, [wait("^SMGR:"),str Data\5 ( Here you wait for the answer "^SMGR:" data[1] and data[4] are zero then no sms are present so you return to loop)
    SERIN2 RXPIN, BAUD,5000,NoSms, [wait("XYZ"),str Data\9] ( here you have skipped the if statement, so you have a sms , you wait for "XYZ" which is your password to be sure is your massage . following your pass you should write the coding massage. Remember to write a couple of word [any things you like minimum 10 characters] at the beginning of your massage. Any sms received that does not contain your pass will be ignored)
    NoSms:'remove SMS
    SEROUT2 TXPIN, BAUD, ["AT+CMGD=1",13] (Here you delete from phone memory the received sms)
    Pause 1000
    goto Loop
    Hope to have cleared
    Alberto
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Pic to relay
    By ruijc in forum General
    Last Post: - 8th November 2007, 20:03
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. Replies: 22
    Last Post: - 9th April 2007, 16:25
  5. SMS decoding / encoding using PIC!
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 19th March 2004, 08:03
