Data logger clock and array
Results 1 to 18 of 18
    Sep 2008
    In order for me to keep it very simple it would take ADC from lipo cells which are 3.7v. I might use a resistor 4.7k on the connector it self or without a resistor since it shouldn't have any spikes in voltage. To take frequency I was thinking just to use 2 resistors 1k and 100ohm to drop the voltage. To power up the pic I was thinking to use TO-92 0.5% LDO and 1 or 2 small capacitors. I'm not going to use voltage reference to keep it simple and ADC probably should work within 1%-3% accurate. As you can see 1 PDIP microchip, 1 LDO, 1-2 capacitors and just connector glued and soldered directly to microchip. Using software rs232 I don’t need Max232 so I can just use serial female connector with 2 resistors and connect it directly to microchip whenever I need to upload the data. Sure I can make PCB at home but I just want to keep it very simple so my friends can use it as well just to pay for parts or so. I bought PicBasic just for fun since I like electronics and I don't intend to make profit but maybe I might sell it for a small fee. I have regular job which pays my bills and I don't mind to spend money for my hobby that I like.
    Quote Originally Posted by PicLearner View Post
    You should be able to drive a PIC directly from one LiPo, no regulators need.
    There's a few PICs out there that have a built-in .6v reference which you could 'reference against'.
    If you think it'll run, go with it... I don't think it'll run and last, but that's just me.
    Same thing with the USB, the connector, 2 wires to the PIC (D+/D-), an extra cap, and the right firmware.
  1. Bit Angle Modulation (BAM) in a PIC
    By Bronx68 in forum mel PIC BASIC Pro
    Last Post: - 24th February 2015, 14:41
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  4. Using SPI with External Interrupts
    Last Post: - 29th June 2008, 05:08
  5. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
