SERIN2 that can recognise a frame error
Results 1 to 2 of 2
    timmers's Avatar
    timmers Guest
    Default SERIN2 that can recognise a frame error
    If a SERIN2 command is executed and the input pin is held low for any reason, then the PBP routine will not time out and hang, even if a time out is specified, until the pin returns high.
    Under hardware use a frame error (FERR) would be flagged.
    So could the SERIN or SERIN2 timeout if a framing error is detected?
    - Please please please!
    Tim.
    Yes, if the cause of the error is the wrong baud rate, parity or the first data bit.
    If the cause is after that, then the SERIN/2 commands will happily receive the rest of the packet, so if the error is "mid stream" some sort of post error checking is needed.
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
