analog help
Results 1 to 6 of 6
Thread: analog help
    Glad to see the site again ...
    Hi Alain,
    Wow, I just got it running again yesterday.
    Nothing get's past you.
    Cheers,
    Apr 2008
    Thanks for your suggestion but I think that would just close my window even further,I wouldnt think this would do much except bring the sweep down to 0 - 20 ,I think this is simply not having the correct value components in place in the voltage divider. But I do think alot which I'm often wrong!
    Quote Originally Posted by cphillips82 View Post
    Yup, you're thinking the wrong way.
    If the usable range was 0-50 before, then changing to 10-bit will increase that range by a factor of 4, which gives 0-200.
    You could change the resistors in the divider to retain pure PBP. But you may also want to consider the other benefit of HPWM10 ... Glitch Free Operation.
    Constantly updating the normal HPWM command can really mess up the waveform. But with Glitch-Free, it doesn't matter how often the DutyCycle is changed. You'll still get "Clean" PWM.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. 16F88 Analog In
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 09:30
  4. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 09:15
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
