12F675 and interrupt
Results 1 to 8 of 8
    Jul 2007
    Default 12F675 and interrupt
    At first, sorry for borring you with my dumb ass question. Totally newbie trying to do a simple thing and canīt figure it out.
    When a 12f675 pin goes low, another pin goes high (to turn on a lamp). Done.
    When the same pin goes high (by the internall pull-up resistor) the pin with a lamp delay for 5 seconds and fade out (with pwm) to zero. Done.
    But thatīs drive me crazy:
    Iīve need some kind of stuff (code of course) that when:
    If a third ping goes high and if the first pin changes to low or if lamp is in delay, delay was cancelled (but yet fade off)
    Try to do with picbasic interrupt, Darrelīs interrupt and nothing. Can anyone show me some directions, code samples, anything :-)
    Thanks and sorry for the bad English.
    Quote Originally Posted by perides View Post
    Let's see your code that doesn't work...
    Hi, Pericles
    "If a third ping goes high and if the first pin changes to low or if lamp is in delay, delay was cancelled (but yet fade off)"
    The simple way ...
    instead of " PAUSE 5000" for the delay ...
    just use
    ' Conditionnal DELAY - tests "Pincancel" pin every 10 ms
    FOR I = 1 to 500
     IF Pincancel = 1 THEN jumpover
    PAUSE 10
    NEXT I
    jumpover :
    ' Fading sequence
    That's all !
    Interrupts ... Interrupts ??? What's that for ???
    Jul 2007
    Thank you all.
    I followed your directions Acetronics but and coded above. Maybe it work, maybe they need some fixes.
    Simulating (no development board in class yet) in proteus, an strange behavior occurs on GPIO.0 they always stays up, even Iīve (I think at least) disabled pullup for them. Other pins appears ok.
    What Iīve missed??
    BTW, Perides, not Pericles. But no problem, common misspelling. :-)
    ' Pinout                                                        *
    ' 1 vdd                                             vss 8       *
    ' 2 gp5/t1cki/osc1/clkin           gp0/an0/cin+/icspdat 7       *
    ' 3 gp4/an3/t1g/osc2/clkout   gp1/an1/cin-/vref/icspclk 6       *
    ' 4 gp3/mclr/vpp                gp2/an2/tockin/int/cout 5       *
    @ device pic12F675, WDT_OFF, PWRT_ON, MCLR_OFF, INTRC_OSC_NOCLKOUT
    define osc 4
    CMCON = 7 'comparator off
    ANSEL = 0 'all digital
    'VRCON = 0 'comparator off
    TRISIO= %000011 '1=in 0=out
    'Enable PULL-UPS
    OPTION_REG.7 = 0 'enable pullu-ps (0 enable/1 disable)
    WPU = %000010 '1=on/0=off each pullup - enable pull-up only TK
    L15 var GPIO.0  'line 15
    TK  VAR GPIO.1  'door sensor
    LAMP VAR GPIO.2 'bulb
    myPWM VAR word
       If TK = 0 Then LAMP = 1 'if TK goes down so LAMP goes UP
       IF TK = 1 and LAMP = 1 then 'if TK goes down and LAMP is yet on
          IF L15 = 1 THEN 'and we have canceled delay
             goto justfade 'so go to fade lamp
             GOTO delay 'and if delay was not canceled go to delay+fade
    GoTo main
    delay:
        FOR myPWM = 1 to 500 '500 loops for 5 second of 10ms delay
            if L15 = 1 then justfade 'if L15 goes up so end delay
            pause 10 'wait 10ms
        next myPWM
    justfade:
        for mypwm = 255 to 1 step -1
            PWM LAMP, myPWM, 255 'pwm bulp
            if TK = 0 then GOTO main 'if TK goes down
        NEXT myPWM
    Last edited by perides; - 23rd September 2008 at 16:23. Reason: Added BTW line :-)
    Sorry, but simulator behaviour is something making me laugh too much ...
    my last program didn't want to run on MPSIM ... but has been working more than fine for two weeks now ... ( Was a periodic signal generator, interrupt driven ...)
    sooo, I can't help you further in the virtual world ...
    BTW ... Periclčs was for joke ...
    Jul 2007
    Hi Alain
    I agree with you about sims.
    The code appears to be in the right way at least?
    Wink
    I never use pullups ...
    you should try to add external resistors ... even on the sim' ...
    you also should avoid PWM command for such uses ... this outputs an awful garbage ( just usable with a RC filter to make a basic D/A converter. )
    as you have written the program ...
    it is easy to do it like that :
     for mypwm = 1000 to 0 step -1
            High LAMP
            PAUSEUS myPWM,
            LOW Lamp
            PAUSEUS (1000 -myPWM)
    Next myPWM
    note PAUSEUS has a minimum duration ... but it is not a problem here !!!
    Jan 2006
    Istanbul
    The code seems to be ok;
    To make it even easier to see, drop the red part.
    and, just use this:
       IF TK = 1 and LAMP = 1 then delay
    Also, your PWM routine happens so fast that your eyes will not catch the fade effect.
    Have a timer loop, say 5ms, in your pwm loop, like "while : wend" and put your pwm pulse inside this "while : wend". Thus, you have a smooth fade effect.
    None of these modifications will make your GPIO pin work though.
    Just some ideas to make your code better.
  1. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 15:39
  2. Interrupt usage
    Last Post: - 20th April 2008, 17:20
  3. ON INTERRUPT not working
    Last Post: - 12th April 2008, 14:41
  4. Instant Interupts with a 12f675
    By wlundonly in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 02:52
  5. inputs on 12F675 (or for that matter any PIC)
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 20:43
