how to use SERIN???
Results 1 to 5 of 5
    Aug 2008
    Default how to use SERIN???
    i try to send data from vb to pic16f877a using serial port.can i use those code below???
    code:
    SO con 0 ' Define serial out pin
    SI con 1 ' Define serial in pin
    N2400 con 4 ' Set serial mode
    B0 var byte
    loop:
    Serin SI,N2400,B0 ' B0 = input character
    If (B0 < "a") or (B0 > "z") Then print ' If lower case, convert to upper
    B0 = B0 - $20
    print:
    Serout SO,N2400,[B0] ' Send character
    Goto loop ' Forever
    can someone teach me how to setting the:
    B0 var byte
    i use pic16f877a which the rx=portc.7 and tx=portc.6...
    If you want to name a pin use var
    SO VAR PORT?.?
    And you will need [] in your SERIN statement.
    And if you are using the software serial (SERIN, SERIN2) then any pin will work if it is digital, pretty much.
    Aug 2008
    for example:
    SO VAR portc.6 'tx pin for pic16f877a
    SI VAR portc.7 'rx pin for pic16f877a
    SERIN SI,N2400,["A"],B0 'Wait until the character “A” is received serially
    am i correct???
    That should do the trick
    Aug 2008
    thanx...i will try it.
  1. Serin EEPROM Programmer
    By dirtbiker5627 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2010, 00:48
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  4. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 12:52
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
