PIC to PIC - Bidirectional LEDs
Results 1 to 6 of 6
    Quote Originally Posted by sswcharlie View Post
    Hi
    Are there any circuits and code for communication between pic with bidirectional leds.
    hey have been touted as a replacement for rfid. All I want is to get a unique code back to the master/reader pic and/or my PC.
    Charlie
    A bidirectional LED is generally regarded as 2 LEDs (usually a RED and a GREEN LED)
    in the same package, with the polarities reversed, thereby you put current across the LED in one direction, it lights up RED, reverse the current and the LED lights up GREEN.
    I don't see how these would be a replacement for RFID in any way....unless I'm stuck in the past or something...
    sswcharlie, You are probably thinking about something like the IrDA devices used in PDA'a and printers to transfer data....
    Aug 2008
    Default PIC to PIC - Bidirectional LEDS
    Hi
    This is what I was basing my request on. Theory has been around for a while, and there are circuits here to make it work.
    Charlie
    Aug 2008
    Default PIC to PIC - Bidirectional LEDs
    Well, how about here:
    http://www.merl.com/papers/docs/TR2003-35.pdf
    Charlie
    Like your article said, only good for a few centimeters. And I do not think it would be very reliable.
    Look at this if you want IR communications.
    http://rentron.com/PicBasic/IR_Chips.htm
    Or are you wanting to build you own opto coupler? For that all you need is a photo transistor and an LED (maybe a resistor or two) and then you can send pulses.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. Replies: 1
    Last Post: - 9th March 2008, 23:17
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
