5V|---------/\/\/\/\------/\/\/\/\------GND
..................10K.....X..... 20K pot
What are you using for a power supply?
Thanks for your response its a Variable bench power supply 0-30V @ 1A
Isaac
If the power supply is stable, thought maybe you were using batteries, I will have to ask if there is a load on the divider.
Other than that, I will have to guess that the pot becomes unstable with a little heat.
Why not use fixed resistors?
isaac, The maximum recomended input impedance for all Microchip Processors is 10K....
