Quote Originally Posted by Charles Linquis View Post
No chance. That takes pins. I'm using all of them already.
What if...and this is a big ol' what if...
Since you're already using the first UART for serial, that pin is taken up...
The 2nd serial port is 'free' for the moment but you want to use it, but can't because there's not enough space for the code.
How about you use that second serial port pin as an I/O and use it to 'steer' the 1st UART's output (and/or input if need be).
I think the code impact would be minimal, just set a pin high or low depending on where the serial has to go...
