Another Mosfet Question
Results 1 to 15 of 15
    With many applications running in the many KHz to MHz region (for reasons of efficiency), gate drivers become a necessity.
    True...I guess I should've quantified those statements a bit.
    The bulk of those MOSFETs are driving a load of LEDs at 76Hz, a few are driving motors at 4882 Hz in other projects (yes, I know, the whine from the motors rocks!!! but I don't have to listen to it!). I've never measured I(g)...probably should. Might be the exact reason why I've had 3 pins fail to 'open-drain wanna-be' in the past couple of years.
    sheepdog's Avatar
    sheepdog Guest
    Shame I did not read this thread before I toasted some irl2203ns, low rds on, logic level, I thought I was good to go. Powered up my battery vehicle drove down the street, heat sink perfectly cool I thought I had cracked it. Return journey mosfet stuck on until the brakes overcame its stall current, pop went the fuse. Only needed the wheels to fall off to finish the circus event.
    It probably went through the Miller effect,shoot through etc,the other irl2003n for braking ending up in the same condition.
    I suppose I live and learn, upped the voltage and used some 2n3055`s from a collection I have for some reason. Worked first time plus I have a bum warmer for the coming winter.
    Talking
    The irl2203ns handles 82 ~ 110A @ 10v drive. Running a 12v supply I have used a PNP/NPN driver. Basically pnp emitter to 12v and collector to gate of FET. A base bias keeps the PNP in the off region and finally a npn pulls the pnp base bias low to turn on the FET. Works like a charm every time I have used this. Largest load I have used thus far is 75A and no problem @ 2kHz.
    Nick
    Quote Originally Posted by Macgman2000 View Post
    So, this is almost like a double-stacked Darlington pair (with extras) and a mix of BJT and FETs?
  1. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 05:02
  2. Mosfet problems
    By Agent36 in forum General
    Last Post: - 2nd February 2008, 22:37
  3. Driving a mosfet directly?
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 12th July 2007, 07:45
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
