Help with Count PORTB.0
Results 1 to 4 of 4
    Puerto Rico
    Exclamation Help with Count PORTB.0
    I need to find a circuit to made pulse to test the Count PORTB.0 to see if is reading correct ..
    thanks for any help.
    My Hobbies is PicBasic PRO
    Use another PIC and FREQOUT.
    Puerto Rico
    Thumbs up
    thanks for help
    Or use the same PIC with hardware PWM. This can output the pulse in the background
    while COUNT works in the foreground.
    Or use Timer1 in counter mode, and just loop through setting/clearing a pin connected to
    the counter input.
        DEFINE OSC 20 ' tested using a 16F877A on LAB-X1
        DEFINE HSER_CLROERR 1 'Automatically clear any USART overflows.
        DEFINE HSER_RCSTA 90h 'Set receive register to receiver enabled
        DEFINE HSER_TXSTA 24h 'Set transmit register to transmitter enabled
        DEFINE HSER_BAUD 9600 'Set baud rate
        Tmr1Val VAR WORD
        Loops   VAR WORD
        NumLoops VAR WORD
        INTCON  = 0           'Global interrupts disabled (peripheral interrupts disabled)
        ADCON1  = 7           'All digital
        TRISA   = %00010000
        TRISB   = %01010001
        TRISC.0=1              'Timer1 clock input connected to RA0
        ' Default idle logic on Timer1 counter input is logic 1
        HIGH PORTA.0
        TMR1L=0 : TMR1H=0
        T1CON = %00000011
        PAUSE 50
        HSEROUT ["Begin",13,10]
    Start:
        ' Generate a random number
        RANDOM NumLoops
        ' Output random number of low-to-high pulses for
        ' Timer1 counter input
        FOR Loops = 1 TO NumLoops
           LOW PORTA.0
           HIGH PORTA.0
        NEXT Loops
        ' Read Timer1 count into word variable Tmr1Val
        Tmr1Val.LowByte = TMR1L
        Tmr1Val.HighByte = TMR1H
        ' Display count
        HSEROut [" Random # = ",DEC NumLoops," Count = ",DEC Tmr1Val,13,10]
        ' Clear Timer1 count before starting over
        TMR1L=0
        TMR1H=0
        goto start
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Multiplex Display with count comand
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 16th October 2005, 05:09
  4. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
  5. count problem
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2004, 16:05
