PIC16F887 and DS1307
Results 1 to 22 of 22
    Jun 2008
    Default PIC16F887 and DS1307
    I've been reading all posts here regarding the DS1307 RTC, but I really can't get it to work.
    I just get the value '0' when trying to read it.
    Is soething in my code is wrong ?
    	RTCSec var byte		' Seconds
    	RTCMin var byte		' Minutes
    	RTCHour var byte	' Hours
    	RTCWDay var byte	' Weekday
    	RTCDay var byte		' Day
    	RTCMonth var byte	' Months
    	RTCYear var byte	' Year
    	RTCCtrl var byte	' Control
    	SetTime var byte	' 12/24 Hour Clock
    	SetSec var byte		' Seconds
    	SetMin var byte		' Minutes
    	SetHour var byte	' Hours
    	SetDay var byte		' Day
    	SetMonth var byte	' Months
    	SetYear var byte	' Year
    	TimeOut var word	' Variable for SetUp Menu Time-Out
    RTCSec=1
    RTCMin=4
    I2CWRITE PORTC.4,PORTC.3,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    I2CRead PORTC.4,PORTC.3,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    SEROUT PORTC.6,6,[254,1]
    toggle PORTD.7 : pause 1000
    SEROUT PORTC.6,6,[254,128,#RTCSec]
    Quote Originally Posted by menta View Post
    A quick search on DS1307 will get you a long way. But since your SEARCH function seems to be broken, I'll show you use mine.
    http://rentron.com/PicBasic/SERLED.htm
    No, this code isn't 100% perfect for what you need, but I'll bet ANYTHING that you can easily modify for your purposes.
    And besides, why are you trying to set the same time that you're trying to read?
    If the set time is zero and the read time is zero, then it seems to me that your program, if that is the whole program, is working correctly.
    Got any pullups on the I2C lines?
    Jun 2008
    Well, i write the time, then I keep reading it, isn't it suppose to be chance every second when I keep reading it ?
    pullups, you mean resistors ? I tried, then I only got 16 or 32 instead of 0
    I don't know if it's supposed to chance every second, but if the clock is running, it may change every second.
    Complete this sentence:
    The value of my resistors connected to +5v and to the I2C clock and data line is __________."
    Jun 2008
    The value of my resistors connected to +5v and to the I2C clock and data line is ____10k____."
    Default rtc
    control register may need to be set
    alsoooooo....
    the I2c read and write address/control string have to be different, I just used binary 00011110 (just an example) to make sure the read write is correctly coded.
    don
  1. Pic16f887 vs ds1307
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 04:12
