Quote Originally Posted by tazntex View Post
Ok, I have been using porta.3 as my serial out and portb.2 was an input from a switch,when the switch was on data was sent out porta.3. I swapped these two and change serial out portb.2 and connected my switch to porta.3. I changed trisa and trisb to along with my variable. Once I did this, as soon as the pic is powered up portb.2 sends data out forever.
I removed everything from the program with the exception of serout label. It still transmits. That was why I asked whether or not certain pins could not be used or used without adding something to the circuit. Thanks again Skimask, hopefully I am making some sense.
Ok, that makes a bit more sense.
Did you do anything else to PortA.3 to make it work for you?
Anything at all?
