connect two pics
Results 1 to 29 of 29
    I agree with Jumper, find the problem.
    Maybe post the problem code??
    SERIAL-- really simple example . Much more to add, but the basic idea.
    SEND
    SEROUT2, PORTX.X, MODE,[DEC 9]
    RECEIVE
    SERIN2, PORTX.X, MODE,[DEC VAR]
    IF VAR = 9 THEN LABELX
    Mar 2006
    China
    Default 877A doh :-)
    If you have connected anything on PORTA and you dont get the results you want.... this one I leave for Melanie to answer if needed :-)
    Show us your HW setup and some code, it should not be rocket science to rotate a DC motor with the 877A.
    So dont give into Plan Z just yet.
    /me
    Jun 2006
    The program I put in both small and big pics are the same,not different programs! On small pics it work on big not well!
    Quote Originally Posted by soki View Post
    And there are hardware differences between the two PICs...
    Is there some reason why we shouldn't see your program? State secret or something?
    Mar 2006
    China
    Default The bigger PIC
    The bigger PIC has tons of nice functions and these needs to be disabled/enabled/taken care of/set up/deactivated......etc
    So tell us what you have connected where and all your regiter settings.. TRIS ADCON etc if you think your code it too big/secret to post here.
    But if you insist of doing a 2 pic project feel free. And if you do that.. why use serial communication when it should be enough to use 2 pins as input on the small pic... as long pin-xx is high rotate left, if pin-yy is high rotate right...
    but... naaah.... if you already have code working for a small pic... what PIC is that? It cant be a 16F84 since that has no A/D....
    the plot thickens
    /me
    Jun 2006
    You guys are great and have humor!
    Thank you for your answers!
    How wrong I can be with that simple program?
    TRISB = 0 ' PORTB is output
    PORTB.0 = 1 'enable1 of L293d is always high so input 1 and input 2 are available
    start:
    PORTB.1 = 1 'input1 of l293d goes high, so output 1 goes high so turns left
    PORTB.2 = 0 'input2 of l293d goes low, so output 2 goes low so turns left
    pause 2000
    PORTB.1 = 0 'the opposite, turns right
    PORTB.2 = 1
    pause 3000
    PORTB.1 = 0 'stop the dc motors
    PORTB.2 = 0
    goto start 'loop
    So what's the problem?
    Jun 2006
    And the schematic, the l293d is also connected right(ground,vs,vss) but not shown on this schematic
    Jun 2006
    not work well the last time I checked, and believe me I tried many times.
    Mar 2006
    China
    Default so..
    You say you have 2 pics, one small and one big and then you use the same code in both. In the small pic everything is dandy but with the 877A it is not working properly.
    the code.... I agree.. what can go wrong... so the answer is probably not in the lines you posted.
    What FQ do your run the pics on, and where do you get this one from?
    Maybe DEFINE OSC XX in the beginning could help ....
    Configurations bits... a long story.. and the bigger the pic.... the longer the story.. the best way to set configuration bits is by adding them to the code. How this is done depends if you use MPASM or not. Search the forum and add these bits into the top of your program... These have a significant effect on the pics behaviour.
    OSC XT HS RC LP
    Watchdog on off
    Brown out or not
    etc etc.. add all config bits you have for the device in the code
    all these you can find in the datasheet....
    And you still didnt answer how you power the pic and if you have caps close to the power pins.
    /me
  1. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  2. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 05:42
  3. connect 2 PICs
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 17:55
  4. Multiple PIC's with 1 crystal
    By puma in forum Schematics
    Last Post: - 20th March 2007, 18:02
  5. Replies: 5
    Last Post: - 21st August 2006, 00:09
