Modifying a variable?
Results 1 to 3 of 3
    ybrisson's Avatar
    ybrisson Guest
    Default Modifying a variable?
    Hello all,
    I would like to know if there's a way to minimise the number of
    "IF THEN" in this following (simplified) situation.
    (I'm new to picbasic!).
    value VAR byte
    x VAR byte
    y0 VAR byte
    y1 VAR byte
    y2 VAR byte
    y3 VAR byte
    y15 VAR byte 'or y VAR byte[16]?
    If x = 0 Then y0 = value
    If x = 1 Then y1 = value
    If x = 2 Then y2 = value
    If x = 3 Then y3 = value
    ... and so forth
    So is there a way to modify variable "y" by using the "x" one?
    ie: yx, y.x, y[x], ???
    Thank you
    This is an alternative you can consider...
    value var byte
    x var byte
    y var byte [16]
    For x=0 to 15
    if y[x]=x then y[x]=value
    next x
    Melanie
    Billyc's Avatar
    Billyc Guest
    Angry PicBasic Pro and PicBasic use different syntax for their compilation source programs
    Can any one shed light on Melabs Compilers PicBasic Pro & PicBasic . THey have different suntaxes declaring /defining variables syntax is totally different. I bought the PicBasic Standard compiler and the manual that comes with it is really really bad. Can anyone direct me to a tutorial paid or unpaid that simply shows the user how to write the correct PicBasic code for THE PICBASIC COMPIIER (Micro Engineering Labs, Inc)it's worth a bottle of Newcastle BRown ! Why do they make it so confusing and why don't they make the syntax the same for both versions of the compiler!! A reply would be appreciated WWC Bolton MA 01740 USA
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. set flags within a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 12:07
  5. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 22:16
